[mapserver-users] Smaller polygon sizes when using mapserver 5.4.1compare to 5.2.0
Steve Lime Steve.Lime at dnr.state.mn.us
Wed Jul 8 10:28:42 EDT 2009
Perhaps you could post image samples and a mapfile?
Steve
>>> On 7/8/2009 at 3:05 AM, in message
<65D1C555BE9443A180F3B1697EF7E69F at BenefonUK.local>, "Nikolai Nikolov"
<nnikolov at gypsii.com> wrote:
> Hi everyone,
> I've just upgraded one of my test servers from 5.2.0 to 5.4.1.  I have an
> issue there and I wonder whether anybody have noticed it.  My map polygones
> seems to be fractionaly smaller (compare to those drawned by 5.2.0).
> I am using the same maps, map files, PHP scripts, etc.  The plygons which
> belong to the same layer, do not quite well "fit" with each other - their
> borders match perfectly before the upgarde to 5.4.1.
> Also, I use BACKGROUNDCOLOR in my map file to create shield like square
> behind a label.  Those squares are now significantly smaller too.
> I wander what causes this effect and what I should do to achieve the same
> image as with 5.2.0?
> Thanks,
> Nick
