[mapserver-users] Fwd: queryByPoint - Street Layer ?
Hussain Hashmi tohashmi at gmail.com
Wed Jul 8 13:20:25 EDT 2009
hi
Can someone here guide me on this issue please.
My Objective is to get attribute values for any selected street (Line).
My client application is based on KaMap.
I have a similar solution for Polygons which works perfectly.
I am trying to query a street layer which gives me the following error.
Warning: [MapServer Error]: msQueryByPoint(): No matching record(s) found in
C:\... on line 84
Warning: [MapServer Error]: msShapefileOpen():
(/ms4w/maps/./city/./city/streets) in c:\... on line 84
MAPFILE
  LAYER
    NAME 'streets_Query'
    GROUP 'streets_Query'
    DATA './city/streets'
    TYPE line
    MAXSCALE 3001
    STATUS ON
    TOLERANCE 5
    TEMPLATE './_templates/Streets_Identify.html'
    METADATA
      "queryable" "true"
       searchfield "ANAME"
       fields "ZIP_CODE"
    END
  END #end layer
PHP MAPSCRIPT
//------- Get Input Parameters.
if (isset($_REQUEST['map']))    {$szMap = $_REQUEST['map'];} else {echo "map
not defined"; die;}
if (isset($_REQUEST['coords'])) {$coords =
explode(',',$_REQUEST['coords']);} else {echo "coordinate not defined";
die;}
//------- Load Mapscript Module.
$szPHPMapScriptModule = 'php_mapscript.'.PHP_SHLIB_SUFFIX;
if (!extension_loaded('MapScript')) {
 dl($szPHPMapScriptModule);
//------- Load Current Map file.
$szMapFile=str_replace('<<Map>>',$szMap,'/ms4w/maps/<<Map>>.map');
$oMap = ms_newMapObj($szMapFile);
//------- SETTING MAP EXTENT to query extent..
$mapExtent = $oMap->extent;
$oMap->setExtent($coords[0],$coords[1],
$coords[0]+0.000001,$coords[1]+0.000001);
//------- SETTING QUERY POINT
$point = ms_newPointObj();
$point->setXY($coords[0], $coords[1]);
//------- Initialize map query.
$oMap->preparequery();
//------- LOOP ON LAYERS and get identify results.
$tot = $oMap->numlayers;
for ($i = 0; $i < $tot; $i++) {
   //------- get map layer.
   $oLayer = $oMap->getLayer($i);
   //------- Verify Layer type
   if ($oLayer->name != 'streets_Query') continue;
   //------- Validate if query succeeds.
   $check_query = $oLayer->queryByPoint($point, MS_SINGLE, 0);
   if ($check_query != MS_SUCCESS) {continue;}
   //------- Open layer for data input.
    $oLayer->open();
   //------- Get the record values corresponding to a result tileindex.
   $oResultCache = $oLayer->getResult(0);
   $oShape = $oLayer->getShape($oResultCache->tileindex,
$oResultCache->shapeindex);
   $aValues = $oShape->values;
   //------- Get the field value.
   echo $aValues['ZIP_CODE'];  echo ";";
   //------- FREE SHAPE
   $oShape->free();
   $oLayer->close();
   break;
} // for i
Best regards,
Mir Hashmi
This message may contain confidential and/or privileged information. If you
have received this message in error,please notify us immediately by
responding to this e-mail and delete it from your system. Thanks for your
cooperation.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090708/2f25cbe5/attachment.html
