[mapserver-users] GetCapabilities response being truncated
John Callahan
john.callahan at UDel.Edu
Thu Jul 9 18:29:15 EDT 2009
Update: I should rephrase my statements...
When run from the command line, c:\apache2.2\cgi-bin\mapserv
"QUERY_STRING=map=...REQUEST=GetCapabilities" only works when output is
to the screen.
When directing the output to a file, like c:\apache2.2\cgi-bin\mapserv
"QUERY_STRING=map=...REQUEST=GetCapabilities" > geomap.xml, then the
output is again truncated.
The limit is not 4053 characters but rather 4096 characters. At least
the number makes more sense.
Using MapServer 5.4.1, x64 in Windows 2008 Server. More details on the
environment is:
http://vbkto.dyndns.org:1280/sdk/PackageInfo.aspx?file=release-1400-x64-gdal-1-6-mapserver-5-4.zip
- John
John Callahan wrote:
> This seems to be a strange problem... I can generate maps fine
> through the browser and mode=map. However, responses to
> GetCapabilities requests are being truncated. They are being
> truncated to 4053 characters. I've tried this using two separate map
> files, using different data, both WMS 1.1.0 and 1.1.1 versions, and
> the same result every time.
> I found some references to old posts but they didn't seem to apply
> here. My data in each map file is just one shapefile. My map file
> symbology is also very simple; it's listed below.
> When run from the command line (mapserv
> "QUERY_STRING=map=...REQUEST=GetCapabilities"), it works perfectly.
> I'm using the x64 stable build from
> http://vbkto.dyndns.org:1280/sdk/Default.aspx (MSVC2005 Win64) Apache
> 2.2.10 and PHP 5.2.5 (x64 versions) if that matters.
> I just don't know what's going on. Sounds like a problem with my
> server setup. Has anyone experienced this before? Any suggestions on
> what I can check? Thanks.
> - John
> ***** start of mapfile
> # Map file created from QGIS project file
> C:/Apache2.2/cgi-bin/maps/geomap12.qgs
> # Edit this file to customize for your map interface
> # (Created with PyQgis MapServer Export plugin)
> MAP
> NAME 'geomap12'
> # Map image size
> SIZE 600 600
> UNITS meters
> CONFIG "PROJ_LIB" "C:/programs/proj/nad/"
> EXTENT 213919.523729 80938.404739 236765.007609 99539.050324
> PROJECTION
> "init=epsg:26957"
> END
> # Background color for the map canvas -- change as desired
> TRANSPARENT ON
> IMAGECOLOR 192 192 192
> IMAGEQUALITY 95
> IMAGETYPE png
> OUTPUTFORMAT
> NAME png
> DRIVER 'GD/PNG'
> MIMETYPE 'image/png'
> #IMAGEMODE PC256
> EXTENSION 'png'
> END
> # Web interface definition. Only the template parameter
> # is required to display a map. See MapServer documentation
> WEB
> # Set IMAGEPATH to the path where MapServer should
> # write its output.
> IMAGEPATH 'C:/Apache2.2/htdocs/output/'
> # Set IMAGEURL to the url that points to IMAGEPATH
> # as defined in your web server configuration
> IMAGEURL '/output/'
> # WMS server settings
> METADATA
> 'wms_title' 'geomap12'
> 'wms_onlineresource'
> 'http://diagproweb01/cgi-bin/mapserv.exe?map=c:/webgis/mapfiles/geomap12.map&'
> 'wms_srs' 'EPSG:26957 EPSG:4326'
> END
> #Scale range at which web interface will operate
> # Template and header/footer settings
> # Only the template parameter is required to display a map. See
> END
> LAYER
> NAME 'geounits'
> TYPE POLYGON
> DATA 'C:\webgis\data\geomap_pubs\geomap12.shp'
> METADATA
> 'wms_title' 'geounits'
> END
> STATUS DEFAULT
> TRANSPARENCY 100
> PROJECTION
> "init=epsg:26957"
> END
> CLASS
> NAME 'geomap12'
> STYLE
> SYMBOL 0
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 144 50 207
> END
> END END
> END
> ***** end of mapfile
> John Callahan, Geospatial Application Developer
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> mapserver-users at lists.osgeo.org
