[mapserver-users] Reprojecting cascading WMS requests
Rob
gis at vanbooth.com
Fri Jul 10 12:23:28 EDT 2009
Hi
I'm obviously having Friday afternoon blindness, as I can't see what I
am doing wrong! I am trying to set up a basic Mapserver install (MS4W
v3.0 Beta 4)
MapServer version 5.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICO
NV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUP
PORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
which points to a WMS service which only supports a single projection.
I want to get my Mapserver to reproject that data on the fly to other
projection systems, but don't seem to be doing it right!
This is my mapfile
MAP
NAME SPIRIT
STATUS ON
SIZE 600 600
EXTENT 0 0 650000 1300000
UNITS METERS
SHAPEPATH "temp"
IMAGECOLOR 255 255 255
#FONTSET 'fontset.txt'
#SYMBOLSET 'temp/examples.sym'
IMAGETYPE JPEG
IMAGEQUALITY 75
IMAGETYPE png
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE rgb
END
IMAGETYPE jpeg
OUTPUTFORMAT
NAME jpeg
DRIVER "GD/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE rgb
END
PROJECTION
"init=epsg:27700"
END
WEB
IMAGEPATH "c:\temp\"
METADATA
WMS_TITLE "WMS Server"
WMS_ABSTRACT "WMS Server."
WMS_ONLINERESOURCE "http://localhost/cgi-bin/mapserv.exe?map=example.map&"
WMS_SRS "EPSG:27700 ESPG:4326"
END
END
LAYER
NAME "layer"
TYPE RASTER
STATUS ON
CONNECTION "http://externalwmshost/&"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:27700"
"wms_name" "layername"
"wms_server_version" "1.1.1"
"wms_formatlist" "image/png,image/jpeg"
END
END
END
END # Map File
but when I make a WMS request against it
http://localhost/cgi-bin/mapserv.exe?map=example.map&request=getmap&service=wms&layers=layer&bbox=53.5,1.4,53.51,1.41&width=400&height=400&version=1.1.1&srs=EPSG:4326&format=jpeg
I get
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidSRS">
msWMSLoadGetMapParams(): WMS server error. Invalid SRS given : SRS
must be valid for all requested layers.
</ServiceException>
</ServiceExceptionReport>
I'm guessing I'm missing something simple, but I don't know what it
is. Any help gratefully accepted!
Thanks
Rob
