[mapserver-users] access problems from cgi-bin on Mac OS X 10.4.11
/ MAMP
rmaurer
jevoudrais0418 at gmail.com
Fri Jul 10 12:28:03 EDT 2009
So I'm a first time MapServer user and have been trying to navigate the
installation process. I think I almost have it, but I am having some last
problems. When I access my executable mapserv file from the command line, I
get this:
This script can only be used to decode form results and should be initiated
as a CGI process via a httpd server.
All sounds good, right? Well, I am using MAMP to host an Apache2.0 server.
The httpd.conf file has the following in it:
Alias /cgi-bin/ "[rootfile]/cgi-bin/"
Directory "[rootfile]/cgi-bin/\>
AllowOverride None
Options ExecCGI FollowSymLinks Indexes
Order allow,deny
Allow from all
/Directory\>
AddHandler cgi-script .cgi .py
I know that first line should probably be ScriptAlias, but I kept getting a
"Permission Denied" message and read in a forum that this was a solution
somebody had come up with, and indeed it worked for me as well.
Anyways, the problem is that in this cgi-bin I have my mapserv executable
(though one of the things I'm thinking is that maybe I need to add something
else to AddHandler to make it think that this file is executable?). But when
I got to //localhost/cgi-bin/mapserv it tries to download the file as
"Untyped Binary Data" and it doesn't execute anthing.
In case its of any help the ls -l for my cgi-bin gives the following
information:
-rwxr-xr-x 1 Rebecca Rebecca 51244 Jul 9 07:52 mapserv
Do I not have this installed correctly? Or is my server just not realizing
that this is executable. I would be thrilled if I could just get to the
point where //localhost/cgi-bin/mapserv just brought up a "No query
information to decode" message, since I think I can handle it from there.
Thank you very much,
Rebecca
View this message in context: http://n2.nabble.com/access-problems-from-cgi-bin-on-Mac-OS-X-10.4.11---MAMP-tp3236919p3236919.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090710/37566cdc/attachment.html
