[mapserver-users] RE: Reprojecting cascading WMS requests (Rob)
Mark Volz
MarkVolz at co.lyon.mn.us
Fri Jul 10 15:57:58 EDT 2009
Rob,
Anyone can correct me if I am wrong on this however I think you have to enter
projection information in 3 times.
1) the projection of your map
2) the projection of your data, in this case the wms service so that
mapserver knows what to reproject from.
3) the projection that you are requesting from the wms service - in the
metadata section.
I am doing this on some of my applications so let me know if your having
trouble, otherwise if someone has a better thought let me know if I am
wasting lines of code.
Example:
MAP
Projection # of the Map
End Projection
Layer
Projection # of the Source
End Projection
Metadata
"wms_srs" "ESPG:27700" #projection you are requesting in WMS
End #Metadata
End #layer
Mark Volz
GIS Specialist
Lyon County, MN
(507) 532-8218
Message: 1
Date: Fri, 10 Jul 2009 17:23:28 +0100
Subject: [mapserver-users] Reprojecting cascading WMS requests
To: mapserver-users at lists.osgeo.org
Message-ID:
<2a955f950907100923m1ad368b7m8eb9e00727d29baa at mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
Hi
I'm obviously having Friday afternoon blindness, as I can't see what I
am doing wrong! I am trying to set up a basic Mapserver install (MS4W
v3.0 Beta 4)
MapServer version 5.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=ICO
NV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUP
PORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS
INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
which points to a WMS service which only supports a single projection.
I want to get my Mapserver to reproject that data on the fly to other
projection systems, but don't seem to be doing it right!
This is my mapfile
MAP
NAME SPIRIT
STATUS ON
SIZE 600 600
EXTENT 0 0 650000 1300000
UNITS METERS
SHAPEPATH "temp"
IMAGECOLOR 255 255 255
#FONTSET 'fontset.txt'
#SYMBOLSET 'temp/examples.sym'
IMAGETYPE JPEG
IMAGEQUALITY 75
IMAGETYPE png
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE rgb
END
IMAGETYPE jpeg
OUTPUTFORMAT
NAME jpeg
DRIVER "GD/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE rgb
END
PROJECTION
"init=epsg:27700"
END
WEB
IMAGEPATH "c:\temp\"
METADATA
WMS_TITLE "WMS Server"
WMS_ABSTRACT "WMS Server."
WMS_ONLINERESOURCE
"http://localhost/cgi-bin/mapserv.exe?map=example.map&"
WMS_SRS "EPSG:27700 ESPG:4326"
END
END
LAYER
NAME "layer"
TYPE RASTER
STATUS ON
CONNECTION "http://externalwmshost/&"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:27700"
"wms_name" "layername"
"wms_server_version" "1.1.1"
"wms_formatlist" "image/png,image/jpeg"
END
END
END
END # Map File
but when I make a WMS request against it
http://localhost/cgi-bin/mapserv.exe?map=example.map&request=getmap&service=w
ms&layers=layer&bbox=53.5,1.4,53.51,1.41&width=400&height=400&version=1.1.1&s
rs=EPSG:4326&format=jpeg
I get
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidSRS">
msWMSLoadGetMapParams(): WMS server error. Invalid SRS given : SRS
must be valid for all requested layers.
</ServiceException>
</ServiceExceptionReport>
I'm guessing I'm missing something simple, but I don't know what it
is. Any help gratefully accepted!
Thanks
Rob
