[mapserver-users] Backgrounds and Graticules in Pseudo-cylindrical Projections
Richard Marsden winwaed at gmail.com
Tue Jul 14 15:55:50 EDT 2009
Thanks Paul.
Good thinking - combine both problems with the same solution!
Cheers,
Richard
On Tue, Jul 14, 2009 at 9:50 AM, Paul Ramsey <pramsey at cleverelephant.ca>wrote:
> The way I would approach this would be to generate a physical
> graticule. That is, an actual polygonal lat/lon grid on the spacing
> desired and with vertex densification between the corners. The
> polygons can then be added and projected, color filled for the effect
> you want, and the outlines highlighted (or not) to form a graticule.
> P
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090714/3b390bcd/attachment.html
