[mapserver-users] Mapfile displaying in red
Fawcett, David
David.Fawcett at state.mn.us
Wed Jul 15 09:59:45 EDT 2009
Paul,
Your polygon data is red because you are telling MapServer to color it
red.
In the class in your layer 'map' (probably not a great layer or class
name), you are using a style to color your polygons.
CLASS
NAME 'map'
STYLE
COLOR 255 0 0
END
LABEL
TYPE bitmap
END
END
You have set the value of the color property to be 255 0 0. Colors are
set as RGB (Red Green Blue) triplets. In that line, you are saying,
'color it with the full amount of red and don't use any green or blue'.
If you change the value to 0 0 255, you will see blue polygons.
For an easy way to come up with prettier colors, take a look at
ColorBrewer:
http://www.personal.psu.edu/cab38/ColorBrewer/ColorBrewer_intro.html
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Paul
Curran
Sent: Wednesday, July 15, 2009 5:20 AM
To: mapser all users
Subject: [mapserver-users] Mapfile displaying in red
Hi
When i load my map file which can be seen below i can view the
outline of map but the actual map displays as red. I am viewing the map
via the mapserver.exe
(e.g.http://localhost/cgi-bin/mapserv.exe?mode=map&map=c:/ms4w/apps/open
layers-2.5/data/test.map&layer='map')
Here is my map file, Can anyone spot were i am going wrong? any
help greatly appreciated.
The uk.shp file i am attempting to load consists of .tiff images
amd was put together using FWTools
MAP
NAME test
# Map image size
SIZE 400 600
IMAGECOLOR 249 245 186
IMAGETYPE PNG24
OUTPUTFORMAT
NAME PNG24
DRIVER 'GD/PNG'
MIMETYPE 'image/PNG'
#IMAGEMODE PC256
EXTENSION 'png'
END
EXTENT -888385.321101 -31000.000000 1548385.321101
1271000.000000
WEB
IMAGEPATH "\ms4w\tmp\ms_tmp\"
IMAGEURL "\ms_tmp\"
METADATA
WMS_SRS "EPSG:4326 EPSG:900913"
END
END
LAYER
NAME 'map'
DATA 'C:\ms4w\apps\openlayers-2.5\data\map.shp'
TYPE polygon
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'map'
STYLE
COLOR 255 0 0
END
LABEL
TYPE bitmap
END
END
END
END
Upgrade to Internet Explorer 8 Optimised for MSN. Download Now
<http://extras.uk.msn.com/internet-explorer-8/?ocid=T010MSN07A0716U>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090715/4652cce9/attachment.html
