[mapserver-users] mapfile projection
Andy Colson
andy at squeakycode.net
Wed Jul 15 10:44:04 EDT 2009
Richard Greenwood wrote:
> On Tue, Jul 14, 2009 at 11:27 AM, Andy Colson <andy at squeakycode.net
> <mailto:andy at squeakycode.net>> wrote:
> Hi all,
> I'm working on my first mapping project, so IANAM (I am no a
> mapper). Here is the projection info from a shapefile I'm using:
> PROJCS["NAD_1983_StatePlane_Iowa_North_FIPS_1401_Feet",
> GEOGCS["GCS_North_American_1983",
> DATUM["D_North_American_1983",
> SPHEROID["GRS_1980",6378137.0,298.257222101]],
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.017453292519943295]],
> PROJECTION["Lambert_Conformal_Conic"],
> PARAMETER["False_Easting",4921250.0],
> PARAMETER["False_Northing",3280833.333333333],
> PARAMETER["Central_Meridian",-93.5],
> PARAMETER["Standard_Parallel_1",42.06666666666667],
> PARAMETER["Standard_Parallel_2",43.26666666666667],
> PARAMETER["Latitude_Of_Origin",41.5],
> UNIT["Foot_US",0.30480060960121924],
> PARAMETER["scale_factor",1.0]]
> I used QGIS to create a mapfile, and it generated this:
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> I was kind of thinking this (Thanks to FrankW for helping me find
> the right epsg code):
> PROJECTION
> 'init=epsg:3417'
> END
> Is the first one even right?
> No
> Would there be a difference?
> The first one is spherical, but State Plane is Cartesian (on a plane).
> Why might I choose one over the other? I'm going to put this into
> postgis, with srid = 3417, will that make any difference.
> Yes.
> (I'd like to avoid re-projections.. I think... don't I?)
> Reprojection isn't evil. You may as well do it right, but the main thing
> with postgis is that you put it in, and take it out, calling the same
> projection. Which could be -1 if you really don't know/care. MapServer
> doesn't set a layer's projection from postgis. If you have a layer(s)
> that's different from the map's overall projection, then you'd need to
> set the projection in the layer definition, not necessarily in postgis.
> Setting a layer's projection different from the map's projection is what
> will trigger reprojection.
> HTH,
> Richard Greenwood
> richard.greenwood at gmail.com <mailto:richard.greenwood at gmail.com>
> www.greenwoodmap.com <http://www.greenwoodmap.com>
Ahh, so QGIS didn't export a projection that matched my data. (I assume
its a default that it always exports...)
Heh.. that's one of those answers that brings up more questions. But
google is helping me out.
Thanks for the help,
-Andy
