[mapserver-users] duplicate labels
andy
andy at squeakycode.net
Fri Jul 17 21:05:03 EDT 2009
Lars Lingner wrote:
> Andy Colson schrieb:
>>>> The help says layer.sizeUnits "Sets the unit of CLASS object SIZE", does
>>>> that include label font size?
>>> it sets the unit of the object size, not the size itself. The font size
>>> is controlled by the SIZE parameter (LABEL object)
>> Then why did the labels font size change?
> I'm not sure about this. If I'm changing sizeunits from meters to
> kilometers, my style looks realy awkward but my labels are stay the same.
>> Here is my entire mapfile, the annotate_pin layer is at the bottom:
>> MAP
>> NAME bremer
>> SIZE 800 800
>> UNITS feet
>> SHAPEPATH '/pub/maps/bremerIA'
>> FONTSET "/pub/www/fonts/fonts.txt"
>> # full extent
>> EXTENT 5166680.718750 3687027.837500 5306080.031250 3802972.662500
>> # testing
>> #EXTENT 5191357.283967 3726454.400032 5205566.339522 3738272.725606
>> PROJECTION
>> "init=epsg:3417"
>> END
>> WEB
>> IMAGEPATH '/tmp/'
>> IMAGEURL '/tmp/'
>> METADATA
>> 'wms_title' 'bremer'
>> 'wms_onlineresource'
>> 'http://my.host.com/cgi-bin/mapserv?map=wms.map&'
>> 'wms_srs' 'EPSG:3417'
>> END
>> END
>> LAYER
>> NAME annotate_pin
>> TYPE line
>> STATUS on
>> # if I comment the SIZEUNITS out it only changes the label size
>> SIZEUNITS feet
>> CLASS
>> NAME "HIGHLIGHT"
>> STYLE
>> COLOR 0 255 0
>> OUTLINECOLOR 0 255 0
>> WIDTH 3
>> END
>> LABEL
>> TYPE truetype
>> FONT "Vera"
>> SIZE 10
>> COLOR 0 0 0
>> BACKGROUNDCOLOR 255 255 255
>> ANGLE follow
>> POSITION auto
>> PARTIALS false
>> MINDISTANCE 95000
>> END
>> END
>> END
>> END
> The mapfile looks fine. I'm unsing MINDISTANCE the same way for
> controlling road labels.
> One other thing you can try is to play with BUFFER for the labels.
> Which version of MapServer are you using? I know along with 5.4 there
> where some enhancements for labeling.
> One last thought: Do you have this problem just with the layer
> "annotate_pin"? Does the labeling of other layers work as you expect?
> lars
I'm using 5.4.1, perl mapscript, via OpenLayers vai WMS. (Jeez, I hope that conveys meaning, because it could really easily be complete gibberish :-) )
Hum... good question. I'll try it Monday when I get back to work. Thanks for the help on this.
-Andy
