[mapserver-users] Error running ./configure on a Linux machine
andy
andy at squeakycode.net
Mon Jul 20 11:47:52 EDT 2009
Michalis Avraam wrote:
> Andy,
> It was edited on Linux and I have tried to make sure it had no white
> space after the \
> Michalis
> On Fri, Jul 17, 2009 at 6:07 PM, andy <andy at squeakycode.net
> Hello all.
> I have tried to compile MapServer 5.4.1 for the last few hours
> to no
> avail. I cannot get past the ./configure command for some
> reason. Any
> input will be greatly appreciated.
> Basically, my problem is that ./configure refuses to recognize
> some of
> the commands I give it for some reason (for example, --with-agg or
> --with-png). It also refuses to find files on the system when I
> specify paths. For example, /usr/sbin/httpd or
> /usr/bin/xml2-config. I
> have made sure that the files are there, installed correctly,
> running
> just fine and are accessible by the user running ./configure.
> Any ideas what might be the problem? The following information
> may be useful.
> Thank you in advance,
> Michalis
> Environment:
> Fedora Core 11 x86
> Intel Core2Duo
> 2GB Ram
> Configure script run:
> ./configure --enable-debug \
> --with-freetype=/usr \
> --with-zlib=/lib \
> --with-png=/usr/lib \
> --with-jpeg \
> --with-libiconv=/usr \
> --with-gd \
> --with-agg=/usr/lib \
> --with-proj=/usr \
> --with-threads \
> --with-geos=/usr/bin/geos-config \
> --with-ogr=/usr/bin/gdal-config \
> --with-gdal=/usr/bin/gdal-config \
> --with-tiff \
> --with-postgis=/usr/bin/pg_config \
> --with-wcs \
> --with-wfsclient \
> --with-wmsclient \
> --with-sos \
> --with-curl-config=/usr/bin/curl-config \
> --with-xml2-config=/usr/bin/xml2-config \
> --with-httpd=/usr/sbin/httpd \
> --with-warnings \
> --with-php=/usr/include/php \
> Configure Report returned:
> MapServer is now configured for
> -------------- Compiler Info -------------
> C compiler: gcc -g -O2 -fPIC -Wall
> C++ compiler: g++ -g -O2 -fPIC -Wall
> Debug: -g -DNEED_NONBLOCKING_STDERR
> Generic NINT:
> -------------- Renderer Settings ---------
> zlib support: -DUSE_ZLIB
> png support:
> palette rgba png support:
> jpeg support: -DUSE_JPEG
> iconv support: -DUSE_ICONV
> AGG support:
> AGG Freetype support:
> Ming(flash) support:
> PDFLib support:
> -------------- Support Libraries ---------
> Proj.4 support:
> Libxml2 support:
> FriBidi support:
> Curl support:
> FastCGI support:
> Threading support:
> GEOS support:
> -------------- Data Format Drivers -------
> native tiff support: -DUSE_TIFF
> PostGIS support:
> EPPL7 support: -DUSE_EPPL
> ArcSDE support:
> OGR support:
> GDAL support:
> Oracle Spatial support:
> -------------- OGC Services --------------
> WMS Server:
> WMS Client:
> WFS Server:
> WFS Client:
> WCS Server:
> SOS Server:
> -------------- MapScript -----------------
> PHP MapScript: no
> Error Messages from configure:
> ./myconfigure.sh: line 8: --with-gd: command not found
> ./myconfigure.sh: line 23: --with-httpd=/usr/sbin/httpd: No
> such file
> or directory
> ./myconfigure.sh: line 25: --with-php=/usr/include/php: No such
> file
> or directory
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> Did you by chance edit myconfigure.sh in windows? Leave around some
> carriage returns or something? Got extra spaces/tabs after the \ ?
> like:
> --with-libiconv=/usr \{tab}
> -Andy
And so it works or it does not?
Assuming it does not: if you make it all on one line, does it work?
-Andy
