[mapserver-users] Shapefile with first FID = 0 not showing..
Douville, Michelle R ILMB:EX
Michelle.Douville at gov.bc.ca
Mon Jul 20 12:30:26 EDT 2009
Hello List,
I am currently using Mapserver 5.2 on Windows Server 2003.
(<!-- MapServer version 5.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI
SUPPORTS=THREADS INPUT=JPEG INPUT=SDE INPUT=ORACLESPATIAL INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE -->)
We have just observed, that when we publish a shapefile that has two
features..
With FID = 0 and FID =1, it only displays the feature with FID = 1..
(for other Shapefiles it is all features greater than 0 only)
For some reason it seems to skip the feature if FID = 0
Has anyone else come across this before?
Is there a work around? (Other than editing the Shapefile),
Many thanks,
Michelle
# Purpose: Mapserver Shapefile Repository Service
# Author: Michelle Douville
# Date: 20090217
MAP
EXTENT 200000 200000 1900000 1900000
SIZE 100 100 #default image size
UNITS meters
SYMBOLSET "e:\sw_nt\mapfiles\symbols.sym"
FONTSET "e:\sw_nt\mapfiles\fonts.lst"
SHAPEPATH "E:\inetpub\wwwroot\imf\upload"
DEBUG 5
CONFIG "MS_ERRORFILE" "test.log"
IMAGETYPE png
IMAGECOLOR 0 0 0
OUTPUTFORMAT
NAME aggpng24
DRIVER AGG/PNG
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
END
WEB
METADATA
WMS_TITLE "User uploaded data" WMS_ABSTRACT "Temporary service
based on user uploaded data."
WMS_ONLINERESOURCE
"http://server/mapserver/mapserv.exe?service=wms&map=E:/inetpub/wwwroot/
imf/upload/shp32973.map&"
wms_srs "EPSG:3785 EPSG:102190 EPSG:26907 EPSG:26707 EPSG:32607
EPSG:3005 EPSG:42102 EPSG:4269 EPSG:4326 EPSG:26708 EPSG:26709
EPSG:26710 EPSG:26711 EPSG:26712 EPSG:26908 EPSG:26909 EPSG:26910
EPSG:26911 EPSG:26912 EPSG:32608 EPSG:32609 EPSG:32610 EPSG:32611
EPSG:32612 EPSG:54004"
wfs_srs "EPSG:3785 EPSG:102190 EPSG:26907 EPSG:26707 EPSG:32607
wfs_maxfeatures "0"
wms_accessconstraints " "
wms_fees "None"
END
IMAGEPATH "E:/server/wwwroot/imf/pdf/"
IMAGEURL "http://server/imf/pdf/"
END
PROJECTION
"init=epsg:3005"
END
LAYER
NAME "shp32973"
DATA shp32973
TYPE POLYGON
LABELITEM "IMF_ID"
CLASS
NAME "IMF_ID"
STYLE
OUTLINECOLOR 0 0 0
END #end style
LABEL
COLOR 255 0 0
FONT arial
TYPE truetype
SIZE 7
POSITION cc
PARTIALS FALSE
BUFFER 1
#BACKGROUNDCOLOR 254 254 254
OUTLINECOLOR 254 254 254
FORCE true
END # end label
END #end class
STATUS ON
PROJECTION
"init=EPSG:3005"
END
METADATA
"wms_title" "test" ## REQUIRED
"wfs_title" "test" ## REQUIRED
"gml_featureid" "IMF_ID" ## REQUIRED
"ows_include_items" "all" ## Optional (serves all attributes for
layer)
"gml_geometries" "shape"
"gml_geom_type" "polygon"
"gml_exclude_items" "GEOMETRY,OBJECTID"
END #metadata
DUMP TRUE
TEMPLATE "foo.html"
#MINSCALEDENOM 0
#MAXSCALEDENOM 1500000
END #end layer
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090720/40688865/attachment.html
