[mapserver-users] Problems when using complex expressions
Adrian Popa
adrian_gh.popa at romtelecom.ro
Tue Jul 21 06:35:12 EDT 2009
Thanks, Andreas,
I've tried your solution (and already looked over the manual) but it
still doesn't match anything...
Also - EXPRESSION ("[myColumn]" =~ /MYREGEXP/i) doesn't match anything
and EXPRESSION "[myColumn]" =~ /MYREGEXP/i complains of a syntax error.
myColumn is the exact same thing as what I use in the layer's CLASSITEM
definition.
I am puzzled... I think I'm using the EXPRESSION syntax the wrong way,
but I'm not sure what I'm doing wrong.
Regards,
Adrian
Andreas Albarello wrote:
> Adrian Popa wrote:
>> EXPRESSION (/MYREGEXP/i) -> doesn't work (doesn't match anything)
>> EXPRESSION /MYREGEXP/i -> works
>> EXPRESSION "[myColumn]" ==1 -> doesn't work (loadClass(): Unknown
>> identifier. Parsing error near (=))
>> EXPRESSION ("[myColumn]" ==1) -> doesn't work (doesn't match anything)
>> EXPRESSION ("[myColumn]" eq "1") -> works
>> EXPRESSION (/MYREGEXP/i) && ("[myColumn]" eq "1") -> doesn't work
>> EXPRESSION /MYREGEXP/i && ("[myColumn]" eq "1") -> doesn't work
>> (loadClass(): Unknown identifier. Parsing error near (&))
>> EXPRESSION ((/MYREGEXP/i) && ("[myColumn]" eq "1")) -> doesn't work
>> I have checked my data and it should match - most likely, my
>> expression is wrong. Any suggestions? What is the correct syntax for
>> mixing regular expressions with other values?
> Adrian,
> have a look at this: http://mapserver.org/mapfile/expressions.html
> As far as mixing regular and other expressions goes, this is the
> correct way to do it:
> EXPRESSION (("[myColumn]" =~ /MYREGEXP/i) && ("[myColumn]" eq "1"))
> Best regards,
