[mapserver-users] Problems when using complex expressions
Adrian Popa adrian_gh.popa at romtelecom.ro
Tue Jul 21 08:19:21 EDT 2009
I managed to find a workaround for my problem: I used a FILTER statement
in the layer definition and an EXPRESSION in my classes:
LAYER
    FILTERITEM "myColumn1"
    FILTER /MYREGEXP/i
    CLASS
       NAME "Test"
       EXPRESSION ( "[myColumn2]" eq "1" )
    END
END
This configuration seems to work - I will test it some more...
If anywone has an idea why the previous examples didn't work - I'd be
happy to hear it out...
Regards,
Adrian
Adrian Popa wrote:
> Thanks, Andreas,
> I've tried your solution (and already looked over the manual) but it
> still doesn't match anything...
> Also - EXPRESSION ("[myColumn]" =~ /MYREGEXP/i) doesn't match anything
> and EXPRESSION "[myColumn]" =~ /MYREGEXP/i   complains of a syntax error.
> myColumn is the exact same thing as what I use in the layer's
> CLASSITEM definition.
> I am puzzled... I think I'm using the EXPRESSION syntax the wrong way,
> but I'm not sure what I'm doing wrong.
> Regards,
> Adrian
> Andreas Albarello wrote:
>> Adrian Popa wrote:
>>> EXPRESSION (/MYREGEXP/i)    -> doesn't work (doesn't match anything)
>>> EXPRESSION /MYREGEXP/i      -> works
>>> EXPRESSION "[myColumn]" ==1 -> doesn't work (loadClass(): Unknown
>>> identifier. Parsing error near (=))
>>> EXPRESSION ("[myColumn]" ==1) -> doesn't work (doesn't match anything)
>>> EXPRESSION ("[myColumn]" eq "1") -> works
>>> EXPRESSION (/MYREGEXP/i) && ("[myColumn]" eq "1")  -> doesn't work
>>> EXPRESSION /MYREGEXP/i && ("[myColumn]" eq "1")  -> doesn't work
>>> (loadClass(): Unknown identifier. Parsing error near (&))
>>> EXPRESSION ((/MYREGEXP/i) && ("[myColumn]" eq "1"))  -> doesn't work
>>> I have checked my data and it should match - most likely, my
>>> expression is wrong. Any suggestions? What is the correct syntax for
>>> mixing regular expressions with other values?
>> Adrian,
>> have a look at this: http://mapserver.org/mapfile/expressions.html
>> As far as mixing regular and other expressions goes, this is the
>> correct way to do it:
>> EXPRESSION (("[myColumn]" =~ /MYREGEXP/i) && ("[myColumn]" eq "1"))
>> Best regards,
> mapserver-users at lists.osgeo.org
