[mapserver-users] Problems when using complex expressions
Andreas Albarello
andreas.albarello at territoriumonline.com
Tue Jul 21 09:02:21 EDT 2009
Adrian Popa wrote:
> Thanks, Andreas,
> I've tried your solution (and already looked over the manual) but it
> still doesn't match anything...
> Also - EXPRESSION ("[myColumn]" =~ /MYREGEXP/i) doesn't match anything
> and EXPRESSION "[myColumn]" =~ /MYREGEXP/i complains of a syntax error.
Adrian,
brackets are always required around expressions like that, so that
explains why the second example you posted doesn't work.
The first one, however, should. I'll admit, though, that I've never used
it with the /i (case-insensitive, I guess) at the end.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi Str. 12
I 39100 Bolzano/Bozen
Phone: +39 0471 068611
Fax: +39 0471 068619
email: andreas.albarello at territoriumonline.com
web: http://www.territoriumonline.com
