[mapserver-users] duplicate labels
Andy Colson
andy at squeakycode.net
Thu Jul 23 11:57:39 EDT 2009
> Andy Colson wrote:
>>> Lars Lingner wrote:
>>>> One last thought: Do you have this problem just with the layer
>>>> "annotate_pin"? Does the labeling of other layers work as you expect?
>>> Hum... good question. I'll try it Monday when I get back to work.
>>> Thanks for the help on this.
>>> -Andy
>> Ok, took longer than I thought to get back to this, but I've tried it
>> with the roads layer and still cannot adjust the distance between labels.
>> here is a screen shot:
>> http://maps.camavision.com/map2.png
>> I've changed MINDISTANCE from 9 to 900000, and the image stays the
>> same... the labels don't move.
>> If I set the layer.sizeunits to feet, then the font size scales with
>> the image as I zoom in and out... I assume the font size is being set
>> to 7 feet instead of 7 pixels? (I have label.size = 7). But still,
>> the mindistance seems to make no difference.
>> Also, some of the labels are being messed up, in the screen shot you
>> can see it. And the road didnt get draw right either.
>> hum... it occurs to me... I dont know how many different lines were
>> used to draw 110th st. If they used multiple lines, would I get a
>> label for each line? Casper seemed to get one label.
>> -Andy
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Christy Nieman wrote:
> Hi,
> (I don't remember if this has been asked yet or not, but...) does your
> OpenLayers application use tiles? Is it possible the duplicate labels
> are actually on separate tiles? If so, you can try setting OpenLayers
> to single tile mode to see if this is indeed the problem. Then you can
> try defining PROCESSING 'LABEL_NO_CLIP=1' for the layer.
> Christy
Ok, that makes a difference. Which makes sense if you think about it.
Thanks for the pointer. However...
http://maps.camavision.com/map3.png
some of the labels came out ok, and some didnt. I removed all the
lables from all other classes and if I change the font color, they all
change, but they never get the backgroud.
This happens regardless of the LABEL_NO_CLIP=1 setting.
-Andy
