[mapserver-users] loadOutputFormat(): error AGG/PNG driver isn't configured.
Galigeo gju at galigeo.com
Fri Jul 24 03:58:26 EDT 2009
Hi kapilmanoj
I do have actually the same problem (exept I use Ubuntu 8.04). I had to
compile mapscript by myself since I use Java and Java mapscript is not
pre-packaged by Ubuntu. Maybe I missed a dependency during the compilation ?
Anyway, if anyone has a solution to this problem, I'd be glad to know it!
Cheers,
Ganael
kapilmanoj wrote:
> Dear users,
> I am using mapserver 5.0.3 on fedora 9. i have been trying out the
> examples
> given in the mapserver 5.x tutorial. i am receiving the following error
> message when attempting to use AGG Output format. i have installed AGG-2.5
> through yum install command in fedora 9....
> error message:   *loadOutputFormat(): General error message. OUTPUTFORMAT
> clause references driver AGG/PNG, but this driver isn't configured.
> This my mapfile for your kind attention
> MAP
>   NAME           Gods own country
>   EXTENT         201621.496941 -294488.285333 1425518.020722 498254.511514
> LAEA
>   #EXTENT         -97.5 41.619778 -82.122902 49.38562 # Geographic
>   SIZE           400 300
>   IMAGECOLOR     255 255 255
>   SHAPEPATH      "/var/www/html/ms4w/aapa/tutorial/data"
>   SYMBOLSET      "/var/www/html/ms4w/aapa/tutorial/symbols/symbols35.sym"
>   FONTSET        "/var/www/html/ms4w/aapa/tutorial/fonts/fonts.list"
>   IMAGETYPE PNG24
>   OUTPUTFORMAT
>     NAME png
>     DRIVER "GD/PNG"
>     MIMETYPE "image/png"
>     IMAGEMODE PC256
>     EXTENSION "png"
>   END
>   OUTPUTFORMAT
>     NAME png24
>     DRIVER "GD/PNG"
>     IMAGEMODE RGBA
>     EXTENSION "png"
>   END
>   OUTPUTFORMAT
>     NAME jpeg
>     DRIVER "GD/JPEG"
>     FORMATOPTION "QUALITY=75"
>     MIMETYPE "image/jpeg"
>     IMAGEMODE RGB
>     EXTENSION "jpg"
>   END
>   OUTPUTFORMAT
>     NAME GTiff
>     DRIVER "GDAL/GTiff"
>     MIMETYPE "image/tiff"
>     IMAGEMODE RGB
>     EXTENSION "tif"
>   END
>   OUTPUTFORMAT
>     NAME AGG
>     DRIVER "AGG/PNG"
>     IMAGEMODE RGB
>   END
>   OUTPUTFORMAT
>     NAME AGGA
>     DRIVER "AGG/PNG"
>     IMAGEMODE RGBA
>   END
>   OUTPUTFORMAT
>     NAME AGGJ
>     DRIVER "AGG/JPEG"
>     IMAGEMODE RGB
>   END
>    WEB
>     IMAGEPATH '/tmp/ms_tmp/'
>     IMAGEURL  '/ms_tmp/'
>   END
>   PROJECTION
>        "init=epsg:2163"
>   END
>   LAYER
>     NAME         districts
>     DATA         parl_04
>     STATUS       OFF
>     TYPE         POLYGON
>     PROJECTION
>       "init=epsg:4326"
>     END
>      CLASSITEM    "NAME"
>       CLASS
>       EXPRESSION 'party'
>       STYLE
>         SYMBOL     0
>         COLOR      232 232 232
>       END
>     END
>   END
>   LAYER
>     NAME         districts
>     DATA         parl_04
>     STATUS       OFF
>     TYPE         ANNOTATION
>     PROJECTION
>       "init=epsg:4326"
>     END
>     CLASSITEM    "NAME"
>     LABELITEM    "WINNER"
>     CLASS
>       EXPRESSION 'party'
>       STYLE
>         COLOR      -1 -1 -1
>       END
>       LABEL
>         COLOR    255 255 255
>         TYPE     TRUETYPE
>         FONT     arial-bold
>         SIZE     12
>         ANTIALIAS    TRUE
>         POSITION     CL
>         PARTIALS     FALSE
>         MINDISTANCE  300
>         BUFFER       4
>       END # end of label
>     END # end of class
>   END # States label layer ends here
>   # End of LAYER DEFINITIONS -------------------------------
> END # end of map file
> can anyone please help me out .....
> suggestion will be appreciated..
> Thanks
> kapilmanoj
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/loadOutputFormat%28%29%3A-error-AGG-PNG-driver-isn%27t-configured.-tp2388899p3314438.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
