[mapserver-users] loadOutputFormat(): error AGG/PNG driver isn't
configured.
Ganaël Jatteau
gju at galigeo.com
Fri Jul 24 04:22:32 EDT 2009
Hi Thomas,
Thanks for your answer. The info I get with mapserver -v is:
MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
It doesn't say anything about AGG, however it has PNG (which I believe use
the same driver).
Cheers,
Ganael
-----Message d'origine-----
De : Thomas Bonfort [mailto:thomas.bonfort at camptocamp.com]
Envoyé : vendredi 24 juillet 2009 10:08
À : Galigeo
Cc : mapserver-users at lists.osgeo.org
Objet : Re: [mapserver-users] loadOutputFormat(): error AGG/PNG driver isn't
configured.
what's the output of
mapserv -v
it should include the AGG key somewhere for agg to be supported.
regards,
thomas
www.camptocamp.com
+33 4 79 26 57 97
On Fri, Jul 24, 2009 at 09:58, Galigeo<gju at galigeo.com> wrote:
> Hi kapilmanoj
> I do have actually the same problem (exept I use Ubuntu 8.04). I had to
> compile mapscript by myself since I use Java and Java mapscript is not
> pre-packaged by Ubuntu. Maybe I missed a dependency during the compilation
> Anyway, if anyone has a solution to this problem, I'd be glad to know it!
> Cheers,
> Ganael
> kapilmanoj wrote:
>> Dear users,
>> I am using mapserver 5.0.3 on fedora 9. i have been trying out the
>> examples
>> given in the mapserver 5.x tutorial. i am receiving the following error
>> message when attempting to use AGG Output format. i have installed
AGG-2.5
>> through yum install command in fedora 9....
>> error message: *loadOutputFormat(): General error message. OUTPUTFORMAT
>> clause references driver AGG/PNG, but this driver isn't configured.
>> This my mapfile for your kind attention
>> MAP
>> NAME Gods own country
>> EXTENT 201621.496941 -294488.285333 1425518.020722
498254.511514
>> LAEA
>> #EXTENT -97.5 41.619778 -82.122902 49.38562 # Geographic
>> SIZE 400 300
>> IMAGECOLOR 255 255 255
>> SHAPEPATH "/var/www/html/ms4w/aapa/tutorial/data"
>> SYMBOLSET "/var/www/html/ms4w/aapa/tutorial/symbols/symbols35.sym"
>> FONTSET "/var/www/html/ms4w/aapa/tutorial/fonts/fonts.list"
>> IMAGETYPE PNG24
>> OUTPUTFORMAT
>> NAME png
>> DRIVER "GD/PNG"
>> MIMETYPE "image/png"
>> IMAGEMODE PC256
>> EXTENSION "png"
>> END
>> OUTPUTFORMAT
>> NAME png24
>> DRIVER "GD/PNG"
>> IMAGEMODE RGBA
>> EXTENSION "png"
>> END
>> OUTPUTFORMAT
>> NAME jpeg
>> DRIVER "GD/JPEG"
>> FORMATOPTION "QUALITY=75"
>> MIMETYPE "image/jpeg"
>> IMAGEMODE RGB
>> EXTENSION "jpg"
>> END
>> OUTPUTFORMAT
>> NAME GTiff
>> DRIVER "GDAL/GTiff"
>> MIMETYPE "image/tiff"
>> IMAGEMODE RGB
>> EXTENSION "tif"
>> END
>> OUTPUTFORMAT
>> NAME AGG
>> DRIVER "AGG/PNG"
>> IMAGEMODE RGB
>> END
>> OUTPUTFORMAT
>> NAME AGGA
>> DRIVER "AGG/PNG"
>> IMAGEMODE RGBA
>> END
>> OUTPUTFORMAT
>> NAME AGGJ
>> DRIVER "AGG/JPEG"
>> IMAGEMODE RGB
>> END
>> WEB
>> IMAGEPATH '/tmp/ms_tmp/'
>> IMAGEURL '/ms_tmp/'
>> END
>> PROJECTION
>> "init=epsg:2163"
>> END
>> LAYER
>> NAME districts
>> DATA parl_04
>> STATUS OFF
>> TYPE POLYGON
>> PROJECTION
>> "init=epsg:4326"
>> END
>> CLASSITEM "NAME"
>> CLASS
>> EXPRESSION 'party'
>> STYLE
>> SYMBOL 0
>> COLOR 232 232 232
>> END
>> END
>> END
>> LAYER
>> NAME districts
>> DATA parl_04
>> STATUS OFF
>> TYPE ANNOTATION
>> PROJECTION
>> "init=epsg:4326"
>> END
>> CLASSITEM "NAME"
>> LABELITEM "WINNER"
>> CLASS
>> EXPRESSION 'party'
>> STYLE
>> COLOR -1 -1 -1
>> END
>> LABEL
>> COLOR 255 255 255
>> TYPE TRUETYPE
>> FONT arial-bold
>> SIZE 12
>> ANTIALIAS TRUE
>> POSITION CL
>> PARTIALS FALSE
>> MINDISTANCE 300
>> BUFFER 4
>> END # end of label
>> END # end of class
>> END # States label layer ends here
>> # End of LAYER DEFINITIONS -------------------------------
>> END # end of map file
>> can anyone please help me out .....
>> suggestion will be appreciated..
>> Thanks
>> kapilmanoj
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
http://n2.nabble.com/loadOutputFormat%28%29%3A-error-AGG-PNG-driver-isn%27t-
configured.-tp2388899p3314438.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
