[mapserver-users] loadOutputFormat(): error AGG/PNG driver
isn'tconfigured.
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Jul 24 04:30:36 EDT 2009
If it does not say it supports AGG then it does not. Without AGG pngs are created with GD renderer. Mapserver -v output will look like this when AGG is included.
MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICO
NV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUP
PORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
-Jukka Rahkonen-
> Ganaël Jatteau wrote
> Hi Thomas,
> Thanks for your answer. The info I get with mapserver -v is:
> MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS
> SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> It doesn't say anything about AGG, however it has PNG (which
> I believe use the same driver).
> Cheers,
> Ganael
> -----Message d'origine-----
> De : Thomas Bonfort [mailto:thomas.bonfort at camptocamp.com]
> Envoyé : vendredi 24 juillet 2009 10:08
> À : Galigeo
> Cc : mapserver-users at lists.osgeo.org
> Objet : Re: [mapserver-users] loadOutputFormat(): error
> AGG/PNG driver isn't configured.
> what's the output of
> mapserv -v
> it should include the AGG key somewhere for agg to be supported.
> regards,
> thomas
> www.camptocamp.com
> +33 4 79 26 57 97
> On Fri, Jul 24, 2009 at 09:58, Galigeo<gju at galigeo.com> wrote:
> > Hi kapilmanoj
> > I do have actually the same problem (exept I use Ubuntu
> 8.04). I had
> > to compile mapscript by myself since I use Java and Java
> mapscript is
> > not pre-packaged by Ubuntu. Maybe I missed a dependency during the
> > compilation
> > Anyway, if anyone has a solution to this problem, I'd be
> glad to know it!
> > Cheers,
> > Ganael
> > kapilmanoj wrote:
> >> Dear users,
> >> I am using mapserver 5.0.3 on fedora 9. i have been trying out the
> >> examples given in the mapserver 5.x tutorial. i am receiving the
> >> following error message when attempting to use AGG Output
> format. i
> >> have installed
> AGG-2.5
> >> through yum install command in fedora 9....
> >> error message: *loadOutputFormat(): General error message.
> >> OUTPUTFORMAT clause references driver AGG/PNG, but this
> >> This my mapfile for your kind attention MAP
> >> NAME Gods own country
> >> EXTENT 201621.496941 -294488.285333 1425518.020722
> 498254.511514
> >> LAEA
> >> #EXTENT -97.5 41.619778 -82.122902 49.38562 # Geographic
> >> SIZE 400 300
> >> IMAGECOLOR 255 255 255
> >> SHAPEPATH "/var/www/html/ms4w/aapa/tutorial/data"
> >> SYMBOLSET
"/var/www/html/ms4w/aapa/tutorial/symbols/symbols35.sym"
> >> FONTSET
"/var/www/html/ms4w/aapa/tutorial/fonts/fonts.list"
> >> IMAGETYPE PNG24
> >> OUTPUTFORMAT
> >> NAME png
> >> DRIVER "GD/PNG"
> >> MIMETYPE "image/png"
> >> IMAGEMODE PC256
> >> EXTENSION "png"
> >> END
> >> OUTPUTFORMAT
> >> NAME png24
> >> DRIVER "GD/PNG"
> >> IMAGEMODE RGBA
> >> EXTENSION "png"
> >> END
> >> OUTPUTFORMAT
> >> NAME jpeg
> >> DRIVER "GD/JPEG"
> >> FORMATOPTION "QUALITY=75"
> >> MIMETYPE "image/jpeg"
> >> IMAGEMODE RGB
> >> EXTENSION "jpg"
> >> END
> >> OUTPUTFORMAT
> >> NAME GTiff
> >> DRIVER "GDAL/GTiff"
> >> MIMETYPE "image/tiff"
> >> IMAGEMODE RGB
> >> EXTENSION "tif"
> >> END
> >> OUTPUTFORMAT
> >> NAME AGG
> >> DRIVER "AGG/PNG"
> >> IMAGEMODE RGB
> >> END
> >> OUTPUTFORMAT
> >> NAME AGGA
> >> DRIVER "AGG/PNG"
> >> IMAGEMODE RGBA
> >> END
> >> OUTPUTFORMAT
> >> NAME AGGJ
> >> DRIVER "AGG/JPEG"
> >> IMAGEMODE RGB
> >> END
> >> WEB
> >> IMAGEPATH '/tmp/ms_tmp/'
> >> IMAGEURL '/ms_tmp/'
> >> END
> >> PROJECTION
> >> "init=epsg:2163"
> >> END
> >> LAYER
> >> NAME districts
> >> DATA parl_04
> >> STATUS OFF
> >> TYPE POLYGON
> >> PROJECTION
> >> "init=epsg:4326"
> >> END
> >> CLASSITEM "NAME"
> >> CLASS
> >> EXPRESSION 'party'
> >> STYLE
> >> SYMBOL 0
> >> COLOR 232 232 232
> >> END
> >> END
> >> END
> >> LAYER
> >> NAME districts
> >> DATA parl_04
> >> STATUS OFF
> >> TYPE ANNOTATION
> >> PROJECTION
> >> "init=epsg:4326"
> >> END
> >> CLASSITEM "NAME"
> >> LABELITEM "WINNER"
> >> CLASS
> >> EXPRESSION 'party'
> >> STYLE
> >> COLOR -1 -1 -1
> >> END
> >> LABEL
> >> COLOR 255 255 255
> >> TYPE TRUETYPE
> >> FONT arial-bold
> >> SIZE 12
> >> ANTIALIAS TRUE
> >> POSITION CL
> >> PARTIALS FALSE
> >> MINDISTANCE 300
> >> BUFFER 4
> >> END # end of label
> >> END # end of class
> >> END # States label layer ends here
> >> # End of LAYER DEFINITIONS -------------------------------
> >> END # end of map file
> >> can anyone please help me out .....
> >> suggestion will be appreciated..
> >> Thanks
> >> kapilmanoj
> >> _______________________________________________
> >> mapserver-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > View this message in context:
> http://n2.nabble.com/loadOutputFormat%28%29%3A-error-AGG-PNG-d
river-isn%27t-
> configured.-tp2388899p3314438.html
> > Sent from the Mapserver - User mailing list archive at Nabble.com.
