[mapserver-users] labeling streets
Raivo Alla
snaperski at gmail.com
Tue Jun 9 02:48:07 EDT 2009
I added red box to visualize line vertices
(style
geomtransform "start"
symbol "box"
color 255 0 0
size 6
end) and the result is displayed here:
http://picasaweb.google.com/snaperski/Ort#5345215158256974066
Best wishes,
Raivo
On Tue, Jun 9, 2009 at 9:18 AM, Thomas
Bonfort<thomas.bonfort at camptocamp.com> wrote:
> Raivo,
> are you sure that your streets only contain one feature?
> If you are using 5.4+, you can check by appending a geomtransform
> style to your street layer, to draw a symbol at the beginning of each
> feature:
> style
> symbol "circle"
> color 255 0 0
> size 15
> end
> regards,
> thomas
> www.camptocamp.com
> +33 4 79 26 57 97
> On Tue, Jun 9, 2009 at 07:50, Raivo Alla<snaperski at gmail.com> wrote:
>> Thank You,
>> so it should be, but somehow in my case it does not work properly.
>> When i have no declaration of MINFEATURESIZE, then the picture looks fine:
>> http://picasaweb.google.com/snaperski/Ort#5345194219497220482
>> But when I add MINFEATURESIZE AUTO, most labels just disappear, even
>> if they have enough space to fit in:
>> http://picasaweb.google.com/snaperski/Ort#5345195269825705586
>> And those labeled straight streets contain only one feature (line
>> feature) each - so the label should fit in decently.
>> Label is declared this way:
>> LABEL
>> TYPE truetype
>> ANTIALIAS true
>> FONT "arial"
>> COLOR 240 240 240
>> OUTLINECOLOR 52 52 52
>> SIZE 9
>> force false
>> MINDISTANCE 250
>> MINFEATURESIZE auto
>> ANGLE follow
>> POSITION cc
>> BUFFER 1
>> END
>> Changing FORCE or POSITION parameters didnt help either....
>> Raivo
>> On Mon, Jun 8, 2009 at 12:55 PM, Christy Nieman<cnieman at dmsolutions.ca> wrote:
>>> Hi,
>>> You could set MINFEATURESIZE to AUTO and then only the labels that fit on
>>> the lines should be drawn.
>>> Regards,
>>> Christy
>>> Raivo Alla wrote:
>>>> Hello!
>>>> I'm stuck in simple-looking problem, but the solution is just hiding
>>>> somewhere.
>>>> The question is: how I can label only those line features, whos label
>>>> does not run over the line like that:
>>>> http://picasaweb.google.com/snaperski/Ort#5344831130138846050
>>>> As street lengths are very different, I cant solve the problem by
>>>> setting suitable MINFEATURESIZE for
>>>> respective MINSCALE,MAXSCALE range.
>>>> All the best,
>>>> Raivo Alla
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
