[mapserver-users] labeling streets
Raivo Alla snaperski at gmail.com
Thu Jun 11 03:18:28 EDT 2009
I think I found the cause.
When declaring ANGLE AUTO, then MINFEATURESIZE auto was working.
But with ANGLE FOLLOW there was a problem displaying labels.
Could it be considered as a bug?
Raivo
On Tue, Jun 9, 2009 at 9:48 AM, Raivo Alla<snaperski at gmail.com> wrote:
> Hi,
> I added red box to visualize line vertices
> (style
>  geomtransform "start"
>  symbol "box"
>  color 255 0 0
>  size 6
>  end) and the result is displayed here:
> http://picasaweb.google.com/snaperski/Ort#5345215158256974066
> Best wishes,
> Raivo
> On Tue, Jun 9, 2009 at 9:18 AM, Thomas
> Bonfort<thomas.bonfort at camptocamp.com> wrote:
>> Raivo,
>> are you sure that your streets only contain one feature?
>> If you are using 5.4+, you can check by appending a geomtransform
>> style to your street layer, to draw a symbol at the beginning of each
>> feature:
>> style
>>  symbol "circle"
>>  color 255 0 0
>>  size 15
>> end
>> regards,
>> thomas
>> www.camptocamp.com
>> +33 4 79 26 57 97
>> On Tue, Jun 9, 2009 at 07:50, Raivo Alla<snaperski at gmail.com> wrote:
>>> Thank You,
>>> so it should be, but somehow in my case it does not work properly.
>>> When i have no declaration of MINFEATURESIZE, then the picture looks fine:
>>> http://picasaweb.google.com/snaperski/Ort#5345194219497220482
>>> But when I add MINFEATURESIZE AUTO, most labels just disappear, even
>>> if they have enough space to fit in:
>>> http://picasaweb.google.com/snaperski/Ort#5345195269825705586
>>> And those labeled straight streets contain only one feature (line
>>> feature) each - so the label should fit in decently.
>>> Label is declared this way:
>>>                LABEL
>>>                        TYPE truetype
>>>                        ANTIALIAS true
>>>                        FONT "arial"
>>>                        COLOR 240 240 240
>>>                        OUTLINECOLOR 52 52 52
>>>                        SIZE 9
>>>                        force false
>>>                        MINDISTANCE 250
>>>                        MINFEATURESIZE auto
>>>                        ANGLE follow
>>>                        POSITION cc
>>>                        BUFFER 1
>>>                END
>>> Changing FORCE or POSITION parameters didnt help either....
>>> Raivo
>>> On Mon, Jun 8, 2009 at 12:55 PM, Christy Nieman<cnieman at dmsolutions.ca> wrote:
>>>> Hi,
>>>> You could set MINFEATURESIZE to AUTO and then only the labels that fit on
>>>> the lines should be drawn.
>>>> Regards,
>>>> Christy
>>>> Raivo Alla wrote:
>>>>> Hello!
>>>>> I'm stuck in simple-looking problem, but the solution is just hiding
>>>>> somewhere.
>>>>> The question is: how I can label only those line features, whos label
>>>>> does not run over the line like that:
>>>>> http://picasaweb.google.com/snaperski/Ort#5344831130138846050
>>>>> As street lengths are very different, I cant solve the problem by
>>>>> setting suitable MINFEATURESIZE for
>>>>> respective MINSCALE,MAXSCALE range.
>>>>> All the best,
>>>>> Raivo Alla
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
