[mapserver-users] MS 5.4.1 Build problems on Windows
Tamas Szekeres szekerest at gmail.com
Wed Jun 17 06:16:37 EDT 2009
Steve,
You could download any of the SDK packages (according to your compiler
version and architecture) supported from this location:
http://vbkto.dyndns.org:1280/sdk/Default.aspx
(see the bottom of the page for the SDKs)
These packages contain all the required stuff for a successful compilation
and the required patch in the regex lib which should make it compile well.
Best regards,
Tamas
2009/6/17 Stephen Woodbridge <woodbri at swoodbridge.com>
> Hi all,
> This is my first time trying to build mapserver under Windows and it is
> dying in the regex-0.12 source with the the errors below. Any thoughts on
> how to resolved this?
> Thanks,
>  -Steve W.
>        cl /nologo /Ox /MD /W3  /EHsc -Ic:\projects\mapserver\..\gdwin32
> -Ic
> :\projects\mapserver\..\proj-4.6.1/src
> -Ic:\projects\mapserver\..\regex-0.12
>   -Ic:\projects\mapserver\..\postgresql-8.3.7/src/interfaces/libpq
> -Ic:\project
> s\mapserver\..\postgresql-8.3.7/src/include -Ic:\projects\mapserver\..\z
> lib-1.2.3    -Ic:\projects\mapserver\..\libpng-1.2.8  -DHAVE_STRING_H
> -DREGEX_MA
> LLOC -DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRLCAT -DNEED_STRRSTR
> -DNEED_S
> TRCASESTR -DUSE_POSTGIS   -DUSE_PROJ -DUSE_PROJ_API_H   -DUSE_GD_PNG
> -DUSE_GD_JP
> EG -DUSE_GD_WBMP -DUSE_GD_GIF -DGD_HAS_GDIMAGEGIFPTR -DUSE_GD_FT
> -DGD_HAS_GETBIT
> MAPFONT -DGD_HAS_FTEX_XSHOW   -DUSE_THREAD    -DIGNORE_MISSING_DATA
>  -DUSE_GD_ANTIALIAS              -DWIN32 -D_WIN32 /c
> egex-0.12\regex.c /Foc:\projects\mapserver\..\regex-0.12\regex.obj
> regex.c
> [snip lots of warnings]
> c:\projects\mapserver\..\regex-0.12\regex.c(4877) : warning C4996:
> 'errcode': Th
> is name was supported during some Whidbey pre-releases. Instead, use the
> standar
> d name errno_t.
>        C:\Program Files\Microsoft Visual Studio
> 9.0\VC\INCLUDE\crtdefs.h(548) :
>  see declaration of 'errcode'
> c:\projects\mapserver\..\regex-0.12\regex.c(4877) : error C2081: 'preg' :
> name i
> n formal parameter list illegal
> c:\projects\mapserver\..\regex-0.12\regex.c(4877) : error C2081: 'errbuf' :
> name
>  in formal parameter list illegal
> 'errbuf_size' :
>  name in formal parameter list illegal
> c:\projects\mapserver\..\regex-0.12\regex.c(4878) : error C2055: expected
> formal
>  parameter list, not a type list
> c:\projects\mapserver\..\regex-0.12\regex.c(4878) : error C2082:
> redefinition of
>  formal parameter 'errcode'
> c:\projects\mapserver\..\regex-0.12\regex.c(4886) : warning C4996:
> 'errcode': Th
> standar
> d name errno_t.
> c:\projects\mapserver\..\regex-0.12\regex.c(4886) : error C2059: syntax
> error :
> 'type'
> c:\projects\mapserver\..\regex-0.12\regex.c(4894) : error C2275: 'errcode'
> : ill
> egal use of this type as an expression
> c:\projects\mapserver\..\regex-0.12\regex.c(4911) : warning C4996:
> 'strcpy': Thi
> s function or variable may be unsafe. Consider using strcpy_s instead. To
> disabl
> e deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
> 9.0\VC\BIN
> \cl.EXE"' : return code '0x2'
> Stop.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090617/9a831fa0/attachment-0001.html
