[mapserver-users] LABEL problem using CGI...
Paul james
pauljame at gmail.com
Wed Jun 17 08:31:50 EDT 2009
You are right...
It is Tiled (using OL)...
In that case, How can I "fix" that effect?
Thanks
On Tue, Jun 16, 2009 at 6:28 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>wrote:
> And this is the result of a single call to the CGI with mode=map?
> MapServer doesn't just invent label placements like this and
> there should be no difference between a single image with mode=map or a
> single call to a mapObj's draw() method.
> Looks to me as if you sample image is the result of merging tiled
> images created from multiple calls to the CGI.
> Steve
> >>> On 6/16/2009 at 9:06 AM, in message
> <33fad6880906160706k5725608dh98ea6887aa82bcb7 at mail.gmail.com>, Paul
> james
> <pauljame at gmail.com> wrote:
> > Hello guys...
> > My layer:
> > LAYER
> > NAME SouthAmerica
> > GROUP "limit"
> > TYPE POLYGON
> > STATUS default
> > CONNECTIONTYPE POSTGIS
> > CONNECTION "x"
> > DATA "x"
> > LABELITEM "name"
> > CLASS
> > COLOR 242 239 213
> > STYLE
> > OUTLINECOLOR 190 190 190
> > WIDTH 1
> > END
> > LABEL
> > COLOR 72 72 72
> > TYPE TRUETYPE
> > FONT Arial
> > SIZE 10
> > ANTIALIAS TRUE
> > POSITION AUTO
> > PARTIALS FALSE
> > MINDISTANCE 0
> > BUFFER 3
> > PRIORITY 1
> > END
> > END
> > END
> > How we can see in picture (attached) the coutrýs name are
> repeated... Using
> > mapscript it is not happen...
> > Ím using Mapserver 5.4 with fastcgi...
> > []́s
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090617/71a8d637/attachment-0001.html
