[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
stela anders stelaanders at gmail.com
Mon Jun 22 11:52:20 EDT 2009
I think It´s not the case...
I tested in Windows 2003/IIS 6.0 (x86) and got same problem...
Stella
2009/6/22 Tamas Szekeres <szekerest at gmail.com>
> I had to replace the 'STATUS ON' with 'STATUS DEFAULT' in the mapfile to
> make it work. Here is the result:
> http://vbkto.dyndns.org:1280/cgi-bin4/mapserv.exe?map=E
> :\tests\TestCGI\map.map&mode=map
> But it seems the original problem couldn't be reproduced here, it might be
> an environment specific issue (I'm using Win2003 x64).
> I'll be trying to set up the same stuff in XP, just in case ....
> Best regards,
> Tamas
> 2009/6/22 stela anders <stelaanders at gmail.com>
>  ok... I´m waiting for the news :p
>> Thanks
>>   2009/6/18 Tamas Szekeres <szekerest at gmail.com>
>>> Hi,
>>> I've set it up (Win2003) but didn't crash, though I get blank images in
>>> cgi mode.
>>> shp2img produces correct image however. I'm a bit uncertain whether the 2
>>> problems are the same but I'll look into this one in more detail shortly.
>>> Tamas
>>> 2009/6/18 stela anders <stelaanders at gmail.com>
>>>> Hi guys!
>>>> I got that binary now :
>>>> http://vbkto.dyndns.org:1280/sdk/release-1500-gdal-mapserver.zip
>>>> Same error Tamas...
>>>> System : Windows XP / IIS 5.1
>>>> Using Postgis as datasourse...
>>>> I made a package with :
>>>> - Mapfile
>>>> - Postgis data
>>>> - Html
>>>> You only need OL js to tryout...
>>>> Or you can try typing :
>>>> http://localhost/cgi-binx/mapserv.exe?map=map.map
>>>> The error is :
>>>> CGI Error
>>>> The specified CGI application misbehaved by not returning a complete set
>>>> of HTTP headers. The headers it did return are:
>>>> Using version 5.2.2 all works fine...
>>>> Stela
>>>> Hi,
>>>>> Some of the guys reported issues with mapserver 5.4+ in normal CGI mode
>>>>> (FastCGI was reported ok) but I couldn't reproduce it myself so it would be
>>>>> helpful if someone could describe the steps (and provide mapfiles/sample
>>>>> data) to check it out.
>>>>> You could also test with the binaries provided from here which appears
>>>>> to be working ok.
>>>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>>>>> Best regards,
>>>>> Tamas
>>>>>>   Hey guys !
>>>>>> That´s my first message here... (I´m from Argentina, sorry about my
>>>>>> bad English)
>>>>>> Is there any bug on Mapserver 5.4 CGI ?
>>>>>> We have a full application using Mapserver 5.2 CGI on Windowns
>>>>>> 2003/IIS ... We tried to update to newest version 5.4 and got a CGI error
>>>>>> Is there any FAQ to upgrade ? Or maybe is it a bug?
>>>>>> Stela
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090622/861362bb/attachment-0001.html
