[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
Tamas Szekeres
szekerest at gmail.com
Mon Jun 22 12:22:53 EDT 2009
Could you post a log of a single request monitored with SysInternals filemon
(and setting up a filter to mapserv.exe). I'd be curious to know which files
are accessed by mapserv.exe during a request on your system.
Best regards,
Tamas
2009/6/22 stela anders <stelaanders at gmail.com>
> I think It´s not the case...
> I tested in Windows 2003/IIS 6.0 (x86) and got same problem...
> Stella
> 2009/6/22 Tamas Szekeres <szekerest at gmail.com>
> I had to replace the 'STATUS ON' with 'STATUS DEFAULT' in the mapfile to
>> make it work. Here is the result:
>> http://vbkto.dyndns.org:1280/cgi-bin4/mapserv.exe?map=E
>> :\tests\TestCGI\map.map&mode=map
>> But it seems the original problem couldn't be reproduced here, it might be
>> an environment specific issue (I'm using Win2003 x64).
>> I'll be trying to set up the same stuff in XP, just in case ....
>> Best regards,
>> Tamas
>> ok... I´m waiting for the news :p
>>> Thanks
>>> 2009/6/18 Tamas Szekeres <szekerest at gmail.com>
>>>> Hi,
>>>> I've set it up (Win2003) but didn't crash, though I get blank images in
>>>> cgi mode.
>>>> shp2img produces correct image however. I'm a bit uncertain whether the
>>>> 2 problems are the same but I'll look into this one in more detail shortly.
>>>> Tamas
>>>> 2009/6/18 stela anders <stelaanders at gmail.com>
>>>>> Hi guys!
>>>>> I got that binary now :
>>>>> http://vbkto.dyndns.org:1280/sdk/release-1500-gdal-mapserver.zip
>>>>> Same error Tamas...
>>>>> System : Windows XP / IIS 5.1
>>>>> Using Postgis as datasourse...
>>>>> I made a package with :
>>>>> - Mapfile
>>>>> - Postgis data
>>>>> - Html
>>>>> You only need OL js to tryout...
>>>>> Or you can try typing :
>>>>> http://localhost/cgi-binx/mapserv.exe?map=map.map
>>>>> The error is :
>>>>> CGI Error
>>>>> The specified CGI application misbehaved by not returning a complete
>>>>> set of HTTP headers. The headers it did return are:
>>>>> Using version 5.2.2 all works fine...
>>>>> Stela
>>>>> Hi,
>>>>>> Some of the guys reported issues with mapserver 5.4+ in normal CGI
>>>>>> mode (FastCGI was reported ok) but I couldn't reproduce it myself so it
>>>>>> would be helpful if someone could describe the steps (and provide
>>>>>> mapfiles/sample data) to check it out.
>>>>>> You could also test with the binaries provided from here which appears
>>>>>> to be working ok.
>>>>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>>>>>> Best regards,
>>>>>> Tamas
>>>>>>> Hey guys !
>>>>>>> That´s my first message here... (I´m from Argentina, sorry about my
>>>>>>> bad English)
>>>>>>> Is there any bug on Mapserver 5.4 CGI ?
>>>>>>> We have a full application using Mapserver 5.2 CGI on Windowns
>>>>>>> 2003/IIS ... We tried to update to newest version 5.4 and got a CGI error
>>>>>>> Is there any FAQ to upgrade ? Or maybe is it a bug?
>>>>>>> Stela
>>>>>>> _______________________________________________
>>>>>>> mapserver-users mailing list
>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090622/1e1bf114/attachment.html
