[mapserver-users] Re: Mapserver WMS seem not to read +towgs84
parameters
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Mar 4 06:17:24 EST 2009
Thanks Frank,
Adding +towgs84=0,0,0 made it. Was it something that I should have been known? Does more fresh epsg file contain towgs84 parameters for epsg:3067 and other comparable projections?
-Jukka-
> -----Alkuperäinen viesti-----
> Lähettäjä: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Lähetetty: 3. maaliskuuta 2009 21:44
> Vastaanottaja: Rahkonen Jukka
> Kopio: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Re: Mapserver WMS seem not to
> read +towgs84 parameters
> Rahkonen Jukka wrote:
> > I forget to mention that I am using epsg:3067 in my WMS
> requests while
> > image data is in epsg:2393 so Mapserver for sure is reprojecting.
> Jukka,
> I believe the problem is that EPSG:3067 expands as:
> +proj=utm +zone=35 +ellps=GRS80 +units=m +no_defs
> with no +towgs84 value. From PROJ 4.6.0 on datum shifts are
> only applied if we know datum information for the source and
> destination coordinate system.
> If you want ETRS89 treated as equivelent to WGS84 you might
> want to add a +towgs84=0,0,0 in the EPSG 3067 entry in the
> epsg file too.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
