[mapserver-users] WMS and map script
Kralidis,Tom [Ontario] Tom.Kralidis at ec.gc.ca
Wed Mar 4 14:01:32 EST 2009
> I am getting junk extent values after calling
> layerObj.getExtent() on a WMS layer.
> This is the WMS server url
> http://www2.demis.nl/wms/wms.asp
> I have used a layer called Countries from that server and
> this is the capability xml for that layer
>                                                 <Layer
> queryable="1" opaque="0">
>   <Name>Countries</Name>
>   <Title>Countries</Title>
>   <BoundingBox SRS="EPSG:4326" minx="-180" miny="-90"
> maxx="180" maxy="83.6333923339844"/>
>                                                 </Layer>
> This is the entry in map file
>   LAYER
>     CONNECTION "http://www2.demis.nl/wms/wms.asp?wms=SAMPLE&"
>     CONNECTIONTYPE WMS
>     METADATA
>       "wms_srs"    "EPSG:4326"
>       "wms_name"              "Countries"
>       "wms_format"            "image/png"
>       "wms_server_version"           "1.1.0"
>     END
>     NAME "Countries"
>     PROJECTION
>       "init=epsg:4326"
>     END
>     STATUS ON
>     TYPE RASTER
>     UNITS DD
>   END
> I get extents values (minx, miny, maxx and maxy) as
> -4.8366978272229995E-26 (which is not same as above in the
> capabilities xml)
> Appreciate any help.
MapServer won't do a GetCapabiilties to get the extent for remote WMS
layers.  If you set LAYER.EXTENT accordingly, layer.getExtent() will
work accordingly.
..Tom
