[mapserver-users] WMS and map script
Murty Maganti
MMaganti at oriongis.com
Wed Mar 4 14:13:04 EST 2009
That won't help me.
I add the wms layer dynamically to map using C# mapscript (and then save
the map object to map file).
I can get the extents from capabilities but layer.extent is readonly and
can't be set.
Thanks
Murty
-----Original Message-----
From: Kralidis,Tom [Ontario] [mailto:Tom.Kralidis at ec.gc.ca]
Sent: Wednesday, March 04, 2009 2:02 PM
To: Murty Maganti; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] WMS and map script
> I am getting junk extent values after calling
> layerObj.getExtent() on a WMS layer.
> This is the WMS server url
> http://www2.demis.nl/wms/wms.asp
> I have used a layer called Countries from that server and
> this is the capability xml for that layer
> <Layer
> queryable="1" opaque="0">
> <Name>Countries</Name>
> <Title>Countries</Title>
> <BoundingBox SRS="EPSG:4326" minx="-180" miny="-90"
> maxx="180" maxy="83.6333923339844"/>
> </Layer>
> This is the entry in map file
> LAYER
> CONNECTION "http://www2.demis.nl/wms/wms.asp?wms=SAMPLE&"
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_name" "Countries"
> "wms_format" "image/png"
> "wms_server_version" "1.1.0"
> END
> NAME "Countries"
> PROJECTION
> "init=epsg:4326"
> END
> STATUS ON
> TYPE RASTER
> UNITS DD
> END
> I get extents values (minx, miny, maxx and maxy) as
> -4.8366978272229995E-26 (which is not same as above in the
> capabilities xml)
> Appreciate any help.
MapServer won't do a GetCapabiilties to get the extent for remote WMS
layers. If you set LAYER.EXTENT accordingly, layer.getExtent() will
work accordingly.
..Tom
