[mapserver-users] AGG FORMATOPTION "PALETTE_FORCE=TRUE" - transparent background
Ivan Mincik ivan.mincik at gmail.com
Thu Mar 5 04:29:33 EST 2009
I am not sure if is it possible to reduce AGG PNG image to 8bit by "PALETTE_FORCE=TRUE" option and keep transparent background.
I went through all posts about this issue and it is not clear for me if I still need to compile mapserver with "--with-experimental-png" switch or it is currently not possible.
I have tested all possible parameters and combinations of RGB or RGBA in  OUTPUTFORMAT and palette file with BLACK BACKGROUND as result.
/usr/lib/cgi-bin/mapserv -v
MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I use mapserver as WMS server.
Currently I have this in mapfile:
	NTERLACE OFF
        TRANSPARENT TRUE
	IMAGETYPE AGG8
         OUTPUTFORMAT
                NAME "AGG8"
                DRIVER "AGG/PNG"
                MIMETYPE "image/png"
                EXTENSION "png"
                IMAGEMODE "RGBA" - #(IMAGEMODE "RGB" is working, nice result without transparent background)
                FORMATOPTION  INTERLACE=OFF
                FORMATOPTION "PALETTE=/s/agg_8bit_pal.txt"
        END
And palette file:
	0,0,0
	255,255,255,255
	230,230,230,0
	174,17,52,255
	174,17,52,255
	242,221,190,255
Please, can anybody clarify this?
Thanks
Ivan
