[mapserver-users] 500 Internal Server Error
Rui Gomes ruijgomes at gmail.com
Thu Mar 5 14:40:35 EST 2009
" Rui, what platform etc.. are you on?"
That is my problem...i try to use a free web host to make a simple
demo of my work.
The server is linux, use apache and permit CGI.
Because i try to build a hello map whithout render any image, i don´t
expect problem whith the libraries so soon. And i have no ideia if i
will can put it working.
2009/3/5 Steve Lime <Steve.Lime at dnr.state.mn.us>:
>>>> Rui Gomes <ruijgomes at gmail.com> 03/05/09 9:20 AM >>>
> " Are you able to get into a shell?"
> I do not think i can do that (or know how do that).
> Thanks anyway
> 2009/3/5 Gregor at HostGIS <gregor at hostgis.com>:
>>> And a few more question: what libraries i need to put in the server?
>>> Where i can find some documentation about the libraries mapserver
>>> need?
>> A technique I find handy for debugging mapserver problems, a bit more useful
>> than "Internal server error", is to go into the Unix shell and use shp2img.
>> I'd use something similar to one of these:
>>  shp2img -o test.png -m mapfile.map
>>  shp2img -o test.png -m mapfile.map -d 999
>>  shp2img -o test.png -m mapfile.map -l lakes,streets
>> When that fails, it'll give you more information as to what went wrong. For
>> example, it will give hints as to shapefiles being transferred in ASCII
>> mode, or the TEMPDIR not being writable.
>> Gregor Mosheh / Greg Allensworth    BS, A+, Network+, Security+, Server+
>> System Administrator, Lead Programmer
>> HostGIS development & hosting services, http://www.HostGIS.com/
>> "Remember that no one cares if you can back up,
>>  only if you can restore." - AMANDA
>                                      Rui Gomes
> mapserver-users at lists.osgeo.org
                                      Rui Gomes
