[mapserver-users] Label encoding
Murty Maganti
MMaganti at oriongis.com
Wed Mar 11 15:47:58 EDT 2009
Hi
Is that list same if map server is compiled with Fribidi or is it
different?
Also, have another issue. I have a map file that loads perfectly fine on
XP and vista. The moment I add encoding attribute, it does not load in
vista (no matter what the coding value). It just hangs in mapObj.draw()
and need to restart IIS. Works fine on XP. Is there any clue where I can
look to resolve the issue. Do I need to install any additional libraries
for Iconv or Fribidi on Vista?
Thanks
Murty
-----Original Message-----
From: Daniel Morissette [mailto:dmorissette at mapgears.com]
Sent: Wednesday, March 11, 2009 2:53 PM
To: Murty Maganti
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Label encoding
Murty Maganti wrote:
> Where can I get the list of valid encodings that can be used in
encoding
> of LABEL section.
MapServer uses the libiconv library to deal with encodings. There is a
list of encodings that the lib supports here:
http://www.gnu.org/software/libiconv/
... and one can also use the "iconv -l" command on a system with
libiconv installed to get the complete list of supported encodings on
that specific system.
Daniel
Daniel Morissette
http://www.mapgears.com/
