[mapserver-users] Label encoding
Tamas Szekeres
szekerest at gmail.com
Thu Mar 12 11:44:06 EDT 2009
Hi Murty,
Could you provide a sample application along with the data so that I could
check out this issue in my Vista machine?
Best regards,
Tamas
2009/3/12 Murty Maganti <MMaganti at oriongis.com>
> Hi
> >The iconv.dll and fribidi.dll should be available to load by the
> application by default.
> >Does this issue exists only when fribidi is compiled in? I can see a
> couple of non-const static variables used by the fribidi library and I
> wonder if we should >protect the access to these functions with locks inside
> the mapserver code in a multi-threaded environment.
> I have the both DLLs present in PATH/binary folders. Though I see
> SUPPORT=FRIBIDI output from map server, but I guess it is going through
> iconv. When a specify wrong encoding like ‘abc’ it throws exception that the
> encoding is not supported by iconv, which means it is using iconv.
> Forgot to mention this previously. There is no problem loading the map file
> (with encoding) in a desktop application on Vista. It hangs when I load in
> ASP.Net environment. But same map file loads fine in ASP.Net on XP machine.
> Appreciate all the help.
> Thanks
> Murty
> *From:* Tamas Szekeres [mailto:szekerest at gmail.com]
> *Sent:* Wednesday, March 11, 2009 6:28 PM
> *To:* Murty Maganti
> *Cc:* Daniel Morissette; mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Label encoding
> 2009/3/11 Murty Maganti <MMaganti at oriongis.com>
> Hi
> Is that list same if map server is compiled with Fribidi or is it
> different?
> Hi,
> I can see the followings added in fribidi (according to
> fribidi-char-sets-list.h)
> #ifdef _FRIBIDI_ADD_CHAR_SET_OTHERS
> _FRIBIDI_ADD_CHAR_SET_OTHERS (UTF8, utf8) /* UTF-8 (Unicode) */
> _FRIBIDI_ADD_CHAR_SET_OTHERS (CAP_RTL, cap_rtl) /* CapRTL (Test) */
> #endif /* _FRIBIDI_ADD_CHAR_SET_OTHERS */
> #ifdef _FRIBIDI_ADD_CHAR_SET_ONE2ONE
> _FRIBIDI_ADD_CHAR_SET_ONE2ONE (ISO8859_6, iso8859_6) /* ISO8859-6
> (Arabic) */
> _FRIBIDI_ADD_CHAR_SET_ONE2ONE (ISO8859_8, iso8859_8) /* ISO8859-8
> (Hebrew) */
> _FRIBIDI_ADD_CHAR_SET_ONE2ONE (CP1255, cp1255) /* CP1255 (MS
> Hebrew/Yiddish) */
> _FRIBIDI_ADD_CHAR_SET_ONE2ONE (CP1256, cp1256) /* CP1256 (MS Arabic)
> #endif /* _FRIBIDI_ADD_CHAR_SET_ONE2ONE */
> As far as I can see this takes precedence over iconv when fribidi is
> compiled in, unless you specify FRIBIDI_NO_CHARSETS when compiling
> mapserver. In the latter case iconv is used to when doing the encoding.
> Also, have another issue. I have a map file that loads perfectly fine on
> XP and vista. The moment I add encoding attribute, it does not load in
> vista (no matter what the coding value). It just hangs in mapObj.draw()
> and need to restart IIS. Works fine on XP. Is there any clue where I can
> look to resolve the issue. Do I need to install any additional libraries
> for Iconv or Fribidi on Vista?
> Does this issue exists only when fribidi is compiled in? I can see a couple
> of non-const static variables used by the fribidi library and I wonder if we
> should protect the access to these functions with locks inside the mapserver
> Best regards,
> Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090312/97e669e4/attachment.html
