[mapserver-users] Internal Server Error - newbie
Guillaume Sueur
no-reply at neogeo-online.net
Sat Mar 14 08:28:54 EDT 2009
Hi
Actually your attachement has not been included, but I may have an idea :
in your url, you must supply the full path to your map file. So if ms4w
is located at the system root it is fine, instead you must correct that.
Regards,
Guillaume
kapil manoj a écrit :
> Hi all,
> I am using mapserver 5.0.3 on fedora 9. i installed it very recently
> in my box , to acknowledge my installation of mapserver in my box , i
> got the message when i call the browser
> http://localhost/cgi-bin/mapserv
> No query information to decode. QUERY_STRING is set, but empty.
> Then i played with the mapserver demo gmap.. its works fine...
> Thenafter i tried to play with the examples given in the mapserver
> tutorial , with the very first example i get error.... when i call the
> link
> http://localhost/cgi-bin/mapserv?map=/ms4w/apps/tutorial/htdocs/example1-1.map&layer=states&mode=map
> <http://localhost/cgi-bin/mapserv?map=/ms4w/apps/tutorial/htdocs/example1-1.map&layer=states&mode=map>
> i get the following error
> The server encountered an internal error or misconfiguration and was
> unable to complete your request.Please contact the server administrator,
> root at localhost and inform them of the time the error occurred, and
> anything you might have done that may have caused the error.More
> information about this error may be available in the server error log.
> Apache/2.2.9 (Fedora) Server at localhost Port 80
> From the above error i understand that something wrong with apache , i
> checked the error log file , ita abig one page error. i couldn't probe
> that error, i have attached the error log file for your perusal
> could anybody please help me out?
> help will be appreciated...
> many thanks,
> zizu
> mapserver-users at lists.osgeo.org
