[mapserver-users] MapServer 5.4 Beta 3 is now available...
Tony Frame
jaframe at net-yan.com
Mon Mar 16 09:26:17 EDT 2009
Thomas,
Extracts from map file are :
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
END
and
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE SMALL
COLOR 0 0 137
END
STATUS ON
END
Before and after legend images attached.
Thanks
Tony
----- Original Message -----
From: "thomas bonfort" <thomas.bonfort at gmail.com>
To: "Tony Frame" <jaframe at net-yan.com>
Cc: <mapserver-users at lists.osgeo.org>
Sent: Sunday, 15 March, 2009 5:56 PM
Subject: Re: [mapserver-users] MapServer 5.4 Beta 3 is now available...
Tony,
the 5.4 codebase has been branched, and the code in trunk is now
milestoned for the 6.0 version, so these kind of changes aren't
unexpected given the rendering changes that will come with the new
version.
as for the the legend issue you raised, could you please show your
mapfile legend block, tell what renderer you're using, and ideally
show a before/after screenshot of the changes?
thanks,
thomas
On Sat, Mar 7, 2009 at 13:59, Tony Frame <jaframe at net-yan.com> wrote:
> Steve,
> 5.4 Beta 3 works fine for me in cgi mode on Fedora 7 & 10 but the latest
> svn
> version (IDs itself as 5.5.0) generates the legend differently. In
> particular the key image sizes have changed and the vertical spacing
> between
> images is very small / zero - I'm pretty sure it worked ok yesterday with
> 5.4 Beta 3.
> My compile options : --with-agg --with-freetype --with-gdal --with-ogr
> --with-proj --with-wfs
> Regards
> Tony
> ----- Original Message ----- From: "Steve Lime"
> <Steve.Lime at dnr.state.mn.us>
> To: <mapserver-dev at lists.osgeo.org>; <mapserver-users at lists.osgeo.org>
> Sent: Friday, 06 March, 2009 12:05 PM
> Subject: [mapserver-users] MapServer 5.4 Beta 3 is now available...
> Greetings all: MapServer 5.4 Beta 3 is now available for download at
> http://mapserver.org/download. A small number of bugs uncovered during
> testing of the second beta have been fixed. The next release should be a
> release candidate and will be available mid-next week. As always any help
> in testing the software is greatly appreciated. Findings should be sent to
> the mapserver-dev (or even just mapserver-users) mailing list.
> The updated 5.4 release plan can be found at:
> http://trac.osgeo.org/mapserver/wiki/54ReleasePlan
> Steve
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090316/16c89025/before.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090316/16c89025/after.png
