[mapserver-users] Prevalence of the use of queryfiles...
Steve Lime Steve.Lime at dnr.state.mn.us
Tue Mar 17 01:14:40 EDT 2009
The problem we have is that to efficiently process result sets from
database-based drivers we need to reference rows in the result set
rather than rows in the dataset. That means the results (with those
types of DATA/CONNECTIONs) can't be cached using the current
mechanism. Shapefiles would still work ok.
The faster query processing is much faster, as much as 24x faster
with DB-based data that it's not practical to do things the old way.
>>> Martin Kofahl <m.kofahl at gmx.net> 03/15/09 2:35 PM >>>
We use them with MapScript. Maybe it's possibile to activate saved
queries only with with a compiler option?
Steve Lime wrote:
> Hi all: Consider this a survey of sorts. I'm wondering how many of
> you make use of saving queries, either via the CGI or MapScript. It's
> an old feature that isn't terribly useful and I'm trying to
> understand the pain the community might incur if they go away in 6.0.
> If you didn't know they existed or how you might use them then it's
> safe to say you don't need 'em.
> Steve
mapserver-users mailing list
mapserver-users at lists.osgeo.org
