[mapserver-users] Oracle Spatial Layer + C# map script
Murty Maganti
MMaganti at oriongis.com
Wed Mar 25 11:58:08 EDT 2009
Hi
I am using a oracle spatial layer which has roughly 100,000 features.
When I call layerObj.getExtents() function, it takes a long time to
return. This is the query sent to oracle by map server
SELECT SDO_AGGR_MBR(GEOM) AS GEOM from (SELECT GEOM FROM ORSPTL.PARCELS)
If I run the query in database, it takes long time to execute. Is there
way to optimize this query to execute fast? Also, I see that layer
extents are stored in USER_SDO_GEOM_METADATA table. Why is map server
not querying against that.
Thanks
Murty
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090325/c1cac70a/attachment.html
