[mapserver-users] ogr connection to postgis problems
Travis Kirstine traviskirstine at gmail.com
Wed Mar 25 14:51:39 EDT 2009
2009/3/25 Stephen Woodbridge <woodbri at swoodbridge.com>:
> Jeff McKenna wrote:
>> Travis Kirstine wrote:
>>> I am trying to test a connection to a postgis db  using ogrinfo and am
>>> having difficulties.  I am running the command on the same server that
>>> hosts the postgis db.  I checked the pg_hba.config file to see if it
>>> allows local connections and everything looks OK but I still get
>>> "Failure" when connecting with ogr.
>>> Am I missing something?
>>> command
>>> ogrinfo -ro PG:'host=server34 dbname=earth user=bob password=suruncle'
>> My thoughts:
>> - since you are on the same server, use host=127.0.0.1
>> - include the port parameter (usually port=5432)
> Have you try from the command line:
> psql -h server34 -U bob earth
> psql -h localhost -U bob earth
> psql -U bob earth
> Should prompt you for the password.
> Only the last on will use the local socket or named pipe. If the last one
> works the try:
> ogrinfo -ro PG:'host= dbname=earth user=bob password=suruncle'
> ogrinfo -ro PG:'dbname=earth user=bob password=suruncle'
> and see if either of these work.
I got the query / connection to work, it seems that the -ro flag was
causing the problem
which is strange.
this works
ogrinfo -sql 'SELECT * FROM counties' PG:'host= dbname=earth user=bob
password=suruncle'
this dosen't
ogrinfo -ro -sql 'SELECT * FROM counties' PG:'host= dbname=earth
I'm not sure what the problem is as the user bob has su privileges
                               List of roles
 Role name | Superuser | Create role | Create DB | Connections | Member of
 postgres  | yes       | yes         | yes       | no limit    |
 bob          | yes       | no          | yes       | no limit    |
Travis K.
Toronto, Canada
"She knows there's no success like failure
and that failure's no success at all."
-Bob Dylan-
