[mapserver-users] WFS Server Request w/Reprojection to Database
joncoign
jncoign at Knology.net
Fri Mar 27 12:16:49 EDT 2009
I have a WFS Server layer defined and have recently needed to provide this service in an alternate projection. The Data is in EPSG:4326 and I need the WFS Service to provide it in Spherical Mercator (SM / EPSG:900913). I have this working properly with the layers projection definition and wfs_srs.
The problem I have is that previously I was passing the %BBOX% parameter to the database stored procedure using an <OGRVRTDataSource> referencing an ODBC connection.
When reprojecting the WFS layer the %BBOX% does not get reprojected so it gets sent to the database in meters as defined in SM. I could reproject this in the Stored Procedure, but my client would prefer I treat their DB as a black box and not make changes. Am I correct in assuming that %BBOX% comes unaltered from the querystring? Is there another variable I can use with Variable substitution to get the BBOX in the data's projection? Or is there a way to reproject %BBOX% variable?
It is critical that I can filter the data coming out of the spatial DB before it gets to MapServer for performance reasons.
Any help is greatly appreciated.
Jon
View this message in context: http://n2.nabble.com/WFS-Server-Request-w-Reprojection-to-Database-tp2545150p2545150.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
