[mapserver-users] FastCGI and trouble writing to the MS_ERRORFILE
joncoign
jncoign at Knology.net
Fri Mar 27 12:25:29 EDT 2009
I just wanted to confirm that we are also having this issue on the Windows Platform (Server 2003 and Server 2008) using the current ms4w binary. We don't make our own mapserver builds so it would not be easy for us to test the fix, but it definately looks like a missing flush call.
One pseudo workaround I have found to force the flush is to put a syntax error in the map file (running in CGI mode) and to issue a request. The parsing error forces the flush. I usually selectively enable debugging so it has not been too bad to add a space in the middle of the word debug and then remove it to continue testing.
Jon
Hi!
Thanks for helping out. Your suggested solution looks reasonable, but I uses the ms4w binary distribution to perform the tests and I haven't set up any compiling environment at the moment. A colleague of mine is doing the compiling on our Linux systems, but he is on vacation for another week. I'll have to wait for him to return to work before doing any compiling.
Regards,
Pål Kristensen
View this message in context: http://n2.nabble.com/FastCGI-and-trouble-writing-to-the-MS_ERRORFILE-tp1972712p2545214.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
