[mapserver-users] read GRASS raster files
Perry Nacionales
naci0002 at umn.edu
Mon Mar 30 17:28:57 EDT 2009
What does "gdalinfo" say about your dataset?
You probably need to define a symbol (with color) in your class. Or you
need to define an expression (cell values, for example) in your class.
Good luck!
-Perry
Steve Smith wrote:
> I'm trying to read a GRASS raster file, from MapServer, but am getting pink tiles.
> The layer in my .map file is set up as follows:
> LAYER
> NAME "JordanMask"
> DATA "/var/www/html/mapdata/grassdata/NCFeet/PERMANENT/cellhd/JordanMask"
> STATUS on
> TYPE raster
> CLASS
> NAME "JordanLakeMask"
> END
> END
> I have gdal-grass-1.4.3 install, and mapserver in installed with gdal support:
> $ /var/www/cgi-bin/mapserv -v
> MapServer version 5.4.0-beta3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I also have gdal installed with GRASS support:
> $ gdal_translate --formats | grep -i grass
> GRASS (ro): GRASS Database Rasters (5.7+)
> If I comment DATA out, in my .map file I do not get the pink tiles, but of course I can not access the data. However, this makes me think it is a syntax error, but the text in LAYER looks correct. Any ideas on what may be the problem?
> Thanks
> Steve
> mapserver-users at lists.osgeo.org
