[mapserver-users] Check layer status in Geomoose
Dan Little
danlittle at yahoo.com
Tue May 12 12:59:03 EDT 2009
You need to have an input type that sends the visiblelayers input to your script.
Are you using GeoMOOSE 1.6.X or GeoMOOSE 2.0 beta?
----- Original Message ----
> From: leonidas <leonidas_liakos at yahoo.gr>
> To: mapserver-users at lists.osgeo.org
> Sent: Monday, May 11, 2009 8:00:03 AM
> Subject: [mapserver-users] Check layer status in Geomoose
> I'm writing a custom tool in geomoose based on php/mapscript.
> I'm trying to get the layer status for each on of my layers using
> $qlayer->status property.
> Always and for each layer it returns the value 2. But there aren't all the
> layers checked in the treeview of geomoose (and according displayed in the
> map). I think that $qlayer->status property always return 2 because it
> checks the status in the mapfile (for my layers the status is DEFAULT) and
> not what is displayed in the map. So how can I get only the layers that are
> displayed in the map (or are checked in the treeview of Geomoose)? I also
> checked the $qlayer->isVisible() property but it also works with the same
> logic (it returns 1 for all layers, displayed or not).Thank you.
> http://n2.nabble.com/Check-layer-status-in-Geomoose-tp2862814p2862814.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
