[mapserver-users] UMN and SVG output
Till Adams adams at terrestris.de
Fri May 15 04:51:29 EDT 2009
Daniel,
firstr of all many thanks for your reply, we already did that:
The upper is the SVG code comes from the mapserver, where the SVG
appears in black, the lower one is the correct one. The differene
between the files is the style definition ' style="fill: none;" ' which
is missing in the upper SVG. Both mapservers are 4.10, are compiled with
the flag "--with-svg" and use exactly the same mapfile.... could it be
that there are any differences in the linked GD library or the
uinterface beteen UMN and GD ...?
Regards - Till
<svg version="1.1" width="1162" height="671"
xmlns="http://www.w3.org/2000/svg"
xmlns:xlink="http://www.w3.org/1999/xlink">
<!-- START LAYER test -->
<path stroke="#ff0000" stroke-width="10" d="M 578 339 L 306 339 L 245
671 L 578 339 M 713 339 L 442 339 L 381 671 L 713 339 z"/>
</svg>
<path stroke="#ff0000" stroke-width="10" style="fill: none;" d="M 578
339 L 306 339 L 245 671 L 578 339 M 781 339 L 510 339 L 449 671 L 781
339 z"/>
</svg>
> Till Adams wrote:
>> Dear list,
>> we have a problem with (old but working) Mapserver 4.10 version and
>> svg output transparency:
>> On one system (solaris 10) everything works fine.
>> On the other system (solaris 10) with exactly the same mapfile, the
>> originally as transparent defined polygons
>> (COLOR -1 -1 -1) come out in black.
>> I guess that GD library is responsible for creating the SVG. Did
>> anybody had this problem before or does anybody have an idea which
>> component may cause this error?
> Till,
> Did you really mean SVG? SVG is a vector format which is rendered by
> the browser, are you using the same browser to access both servers?
> I'd suggest you start by comparing the SVG output from both to try to
> figure the difference (it's XML-ish) between the output from your two
> servers, and then we can go from there.
> Daniel
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
