[mapserver-users] select one column values from a table
Paolo Corti
pcorti at gmail.com
Tue May 19 06:39:11 EDT 2009
hi friend...thanks for ur response...
let me desribe my requirement in detail...
i have one table n_123 and in that table i have 2 columns PLO_900,PLO_901.
PLO_900 PLO_900
af op_1
3f op_2
h7 op_3
i need the result like as follows
af
3f
h7
that means all the values from the first column....the specified code u
mentioned giving me only one record....can u help me ?
Basically you have 2 ways:
1) like in my sample code, iterate all the features and access the field
values with layer.getItem(i)
2) much better for performance and if your layer is in a spatial database:
do a select distinct. If for example you are using PostGis from .NET use the
postgres driver (npgsql: http://npgsql.projects.postgresql.org/) and with a
sqlcommand use this commandtext: select distinct(yourfield) from yourtable
best regards
Paolo
View this message in context: http://n2.nabble.com/select-one-column-values-from-a-table-tp2931342p2938771.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
