[mapserver-users] Get the nearest layer with mapscript...
Paul james
pauljame at gmail.com
Wed May 20 09:53:53 EDT 2009
Hi David...
In my system the user SELECT the active layer (dropdown), and so he can
"query" it selecting a a area or a point ....
But, I´d like to take off that dropdown to select active layer... And when
user click on map to query, I figure out what layer was clicked and query
that...
Paul
On Wed, May 20, 2009 at 10:44 AM, Fawcett, David
<David.Fawcett at state.mn.us>wrote:
> Paul,
> I would guess that this really is about the client-side map interface and
> not about MapServer. Does your interface only allow them to click/select
> the topmost layer? Do you pick which layer is selectable? Do you let them
> pick which layer is selectable? Is it random?
> Tells us more about the client-side app.
> David.
> -----Original Message-----
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Paul james
> *Sent:* Wednesday, May 20, 2009 7:55 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Get the nearest layer with mapscript...
> Thanks Pano...
> But It´s not that simple...
> What I need is figure out what LAYER was clicked...
> Paul
> On Wed, May 20, 2009 at 6:43 AM, Pano Voudouris <pvoudouris at gaiocorp.com>wrote:
>> Probably don’t understand what exactly you are trying to achieve here
>> but it is not as simple as map.getLayer(0) to get the topmost layer? And
>> once you have the layer object use one of the query function to select the
>> record? E.g. myLayerObj.queryByPoint ?
>> Pano
>> *Sent:* 19 May 2009 21:46
>> *Subject:* [mapserver-users] Get the nearest layer with mapscript...
>> Hello guys...
>> I have several layers (lines, points, poly) ...
>> I´m developing a measure tool... User can click on map and I have to
>> select that layer to calculate de Area with postgis...
>> I´m trying to do that WITHOUT using "LAYER ACTIVE SYSTEM"...
>> Is That possible using mapscript? How Can I find the nearest and toppest
>> layer ?
>> Thanks!
>> Paul
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090520/844e6f15/attachment.html
