[mapserver-users] Get the nearest layer with mapscript...
Dan Little
danlittle at yahoo.com
Wed May 20 12:53:06 EDT 2009
Would a "drill down" identify be appropriate for your application? Just query all of the layers?
To: "Fawcett, David" <David.Fawcett at state.mn.us>
Cc: mapserver-users at lists.osgeo.org
Sent: Wednesday, May 20, 2009 8:53:53 AM
Subject: Re: [mapserver-users] Get the nearest layer with mapscript...
Hi David...
In my system the user SELECT the active layer (dropdown), and so he can "query" it selecting a a area or a point ....
But, I´d like to take off that dropdown to select active layer... And when user click on map to query, I figure out what layer was clicked and query that...
Paul
On Wed, May 20, 2009 at 10:44 AM, Fawcett, David <David.Fawcett at state.mn.us> wrote:
Paul,
I
would guess that this really is about the client-side map interface and not
about MapServer. Does your interface only allow them to click/select the
topmost layer? Do you pick which layer is selectable? Do you let
them pick which layer is selectable? Is it random?
Tells
us more about the client-side app.
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Paul james
Sent: Wednesday, May 20, 2009 7:55 AM
To: mapserver-users at lists.osgeo.org
Thanks Pano...
But It´s not that simple...
What I need is figure out what LAYER was clicked...
Paul
On Wed, May 20, 2009 at 6:43 AM, Pano Voudouris <pvoudouris at gaiocorp.com> wrote:
Probably don’t understand what exactly you are trying to achieve here but it is not as simple as map.getLayer(0) to get the topmost layer? And once you have the layer object use one of the query function to select the record? E.g. myLayerObj.queryByPoint ?
Pano
From:mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Paul james
Sent: 19 May 2009 21:46
Subject: [mapserver-users] Get the nearest layer with mapscript...
Hello guys...
I have several layers (lines, points, poly) ...
I´m developing a measure tool... User can click on map and I have to select that layer to calculate de Area with postgis...
I´m trying to do that WITHOUT using "LAYER ACTIVE SYSTEM"...
Is That possible using mapscript? How Can I find the nearest and toppest layer ?
Thanks!
Paul
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090520/38aac59b/attachment.html
