[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error on IIS(5.1 and 6.0) ... Possible BUG?
Paul james pauljame at gmail.com
Fri May 29 12:26:18 EDT 2009
Yes Daniel...  I deleted all previous files and put only 5.4 files... My
mapscript application is working fine on 5.4...
But the CGI dont...
Tested on Windows XP (IIS 5.1) and Windows 2003(IIS 6.0)...
Paul
On Fri, May 29, 2009 at 12:56 PM, Daniel Morissette <
dmorissette at mapgears.com> wrote:
> Paul james wrote:
>> Hi Daniel...
>> I got the binaries from Tamas build :
>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>> And from MS4W 3.0 beta2...
>> Same result with both...
>> That error you got is my fault... I took off the :
>> IMAGE "..\Map.png"
>> from REFERENCE definition when copy the code to email...
>> My application works fine with 5.2 binary in iis 5.1 and 6.0
>> Just replacing with 5.4 binary I got that 502 error...
> Hopefully you always make sure you update all DLLs as well when you
> "replace with 5.4 binary"? Even if the DLLs have the same names, if they
> come from different build environments or versions they may not be
> compatible and could cause the kind of crashes that you are experiencing.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090529/f60b6bf0/attachment.html
