[mapserver-users] Place names...?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri May 29 13:59:27 EDT 2009
Mapserver needs LABELITEM in the layer definitions before it knows what to write into labels. And then it needs a whole LABEL section that defines how the labels should look like on a map. Label settings are described in
http://mapserver.org/mapfile/label.html#label
However, I cannot find there a basic example of how to use built-in bitmap fonts for labeling. That would be the most simple way to start with.
-Jukka Rahkonen-
Chris Green wrote:
Hi all
Apologies in advance if this turns out to be a stupid question, but I can't
find a way to make Map Server v5.0 display place names. I have created a
shape file with points for towns and cities, each of which has a label. If I
check this layer with Quantum GIS (which I used to create the points) I can
display both the points and the labels showing town and city names. However
when I define this layer in the mapfile with type 'point' MapServer gives me
a display of the points but not the labels. If I define it as type
'annotation' I don't see either points or labels. I feel sure I am missing
something obvious but after quite a few hours I am stuck. Can anyone
suggest what I am doing wrong?
Chris Green
