[mapserver-users] TOLERANCE
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Nov 23 19:07:50 EST 2009
Hi Ted:
1) Yes.
2) The tolerances used in a feature query are from the layer(s) being
queried, that
is, the qlayer if you set that explicitly.
I wonder if you might be running into problems because your map units
are in
DD and/or the projections being done. Any chance you could whip up a
test
dataset to work from?
Steve
>>> Ted Spradley <tspradley at snoogems.com> 11/23/09 3:31 PM >>>
Hi all,
Simplifying from earlier.
1. Does TOLERANCE apply to polygons (layers)?
The documentation says it only applies to points, but I am finding
postings referring to it applying to
line and polygon features.
If yes to #1,
2. Using mode = itemfeaturequery to find a polygon in slayer=LAYER A,
then
qlayer=LAYER B, finding the
polygons with in TOLERANCE of the polygon in LAYER A.
Does TOLERANCE get set in LAYER A or LAYER B? (tried it both ways and
it
doesn't seem to matter)
Thanks in advance,
Ted S
Here is the MAP file
MAP
NAME "urlCountyApraisalDistricts" # WMS
Capabilities requires a Name and
a Title tag for every
# layer. The Map’s
NAME and wms_title metadata will be used
# to set the root
layer’s name and title in the
# GetCapabilities
XML output. The root layer in the WMS
# context
corresponds to the whole mapfile
SIZE 800 800
EXTENT -125 24 -65 50
UNITS DD
IMAGECOLOR 100 100 255
PROJECTION
"init=epsg:4326"
END
IMAGETYPE PNG24
SHAPEPATH '/var/www/vhosts/url.com/subdomains/maps/mapserver/data/'
STATUS ON
SYMBOLSET "/usr/mapserver/mapserver-5.4.1/symbols/examples.sym"
FONTSET '/usr/share/fonts/fonts.list'
CONFIG "MS_ERRORFILE"
"/var/www/vhosts/url.com/subdomains/maps/mapserver/logs/cad1.log"
WEB
TEMPLATE "mapserver.html"
IMAGEPATH
"/var/www/vhosts/url.com/subdomains/maps/httpdocs/temp/"
IMAGEURL "/temp/"
METADATA
"wms_title" "url WMS County Detail"
"wfs_title" "url WFS County Detail"
"wms_srs" "EPSG:4326"
"wfs_srs" "EPSG:4326"
"wms_onlineresource"
"http://maps.url.com/cgi-bin/mapserv?map=/var/www/vhosts/url.com/subdomains/maps/httpdocs/mapserver/my_tests/county_cads&"
"wfs_onlineresource"
END
END
QUERYMAP
STATUS ON
STYLE hilite
COLOR 212 212 212
END
OUTPUTFORMAT
NAME 'selected_parcel'
DRIVER 'TEMPLATE'
MIMETYPE 'text/html'
FORMATOPTION 'FILE=selected_parcel.tmpl'
END
SCALEBAR
STATUS embed
INTERVALS 5
ALIGN left
POSITION lr
SIZE 600 8
# UNITS feet
COLOR 0 0 0
BACKGROUNDCOLOR 212 212 212
END # End Scalebar
# Layer 'parcels' will draw individual property parcels and provide
owner
data
LAYER
NAME 'parcels'
TYPE POLYGON
STATUS DEFAULT
DEBUG 3
TEMPLATE 'dummy'
DUMP TRUE
MAXSCALEDENOM 7000
CONNECTIONTYPE POSTGIS
CONNECTION "dbname=cad1 user=user password=password host=localhost
port=5432"
DATA "the_geom from parcels using unique gid using
srid=-1"
LABELITEM "owner_name"
# FILTERITEM objectid
FILTER (objectid == "%objectid%")
PROCESSING 'LABEL_NO_CLIP=1'
# TOLERANCEUNITS FEET
# TOLERANCE 300
CLASS
# SYMBOL 'circle'
# SIZE 2
# OUTLINECOLOR 212 212 212
STYLE
WIDTH 1
OUTLINECOLOR 0 255 0
END
LABEL
COLOR 0 0 0
#OUTLINECOLOR 0 255 0
TYPE TRUETYPE
FONT ARIAL
SIZE 10
BUFFER 5
MINFEATURESIZE 20
# PARTIALS FALSE
POSITION AUTO
ANGLE AUTO
END
END # End class
PROJECTION
"init=epsg:2278"
END
METADATA
"wms_title" "County Property Parcels"
"wfs_title" "County Property Parcels"
"wms_srs" "epsg:102740"
"gml_include_items" "all"
"gml_featureid" "ogc_fid" ## REQUIRED
"qstring_validation_pattern" '.'
END
END # End layer 'parcels'
# This layer to compare geometries with previous
LAYER
NAME 'parcels_01'
TYPE POLYGON
STATUS ON
DEBUG 3
TEMPLATE 'dummy'
DUMP TRUE
MAXSCALEDENOM 7000
port=5432"
srid=-1"
# FILTER - valid SQL WHERE clause
TOLERANCEUNITS feet
TOLERANCE 300
CLASS
# SYMBOL 'circle'
# SIZE 2
STYLE
WIDTH 2
COLOR 139 136 120
END
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT ARIAL
SIZE 10
MINFEATURESIZE 20
# PARTIALS FALSE
POSITION AUTO
ANGLE AUTO
END
END # End class
PROJECTION
"init=epsg:2278"
END
METADATA
"wms_title" "County Property Parcels Comparison Layer"
"wfs_title" "County Property Parcels Comparison Layer"
END
END # End layer 'parcels_01'
END # End map
View this message in context:
http://n2.nabble.com/TOLERANCE-tp4054120p4054120.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
