[mapserver-users] AGG Rendering problem
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Oct 27 18:41:15 EDT 2009
Tony,
This sounds like a nasty bug because it is very subtle. Can you pleas
create a ticket with the symbol and a mapfile that will reproduce this
problem.
Thanks,
-Steve W
Tony Baylis wrote:
> Thanks to Rahkonon and and Paul for their responses but neither solved
> the problem. I eventually moved a map from my existing working
> mapserver/agg instance to the rebuilt one and after doing the required
> bits to point it at the right data IT also did not work in AGG rendering
> mode.
> I then removed all layers and started adding them back to the map one by
> one to see if it was a problem with the layer setup somewhere...sure
> enough one of the layers was referencing a symbol in the symbolset that
> AGG obviously dislikes. Once I removed the 'SIZE' criteria from the
> 'STYLE' AGG rendering worked. Since putting the original map together I
> have created another (better) symbol for this object and using this all
> is working well.
> So there you have it...a symbol working with standard rendering but not
> with AGG, the result being the application seemed to lose connection.
> Tony
> Tony Baylis
> Spatial Information Specialist
> Resource and Exploration Mapping
> Suite 8, 290 Boundary St
> Spring Hill QLD 4000
> Ph 3832 1600
> Fax 3832 1603
> Mob 0419 759 131
> Email tony.baylis at resexmap.com.au
> www resexmap.com.au
> Rahkonen Jukka wrote:
>> Hi,
>> Try adding MIMETYPE to outputformat. I guess that without it Mapserver
>> is using default for jpeg requests. If you use, while testing, your
>> own mimetype like MIMETYPE "image/jpeg2" and in request use
>> &FORMAT=image/jpeg2 you should be able to compare what happens with
>> image/jpeg and image/jpeg2. If jpeg2 works you know that Mapserver if
>> using your own imageformat because otherwise image/jpeg2 would not be
>> recognised. Then rename AGG MIMETYPE to image/jpeg and see if the
>> output now seems to be generated by AGG.
>> -Jukka Rahkonen-
>>> -----Alkuperäinen viesti-----
>>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Tony Baylis
>>> Lähetetty: 26. lokakuuta 2009 15:15
>>> Vastaanottaja: mapserver-users at lists.osgeo.org
>>> Aihe: [mapserver-users] AGG Rendering problem
>>> Hi all,
>>> This is my first post in a long time so be gentle...My problem is I
>>> have finally updated an old server to use MapServer 5.4.2 and want to
>>> use AGG rendering I have done this without a problem on another
>>> server earlier in the year but for some reason whenever I add the
>>> 'OUTPUTFORMAT' section and remove 'IMAGETYPE' I get a Connection Lost
>>> type error from the browser. Replace 'IMAGETYPE' and the connection
>>> is restored but the map is definitely not anti-aliased.
>>> Below is the relevant section from my mapfile and below that the
>>> output from a ./mapserv -v. Both outputs match the server that works.
>>> #IMAGETYPE JPEG
>>> OUTPUTFORMAT
>>> NAME "AGG_JPEG"
>>> DRIVER "AGG/JPEG"
>>> IMAGEMODE RGB
>>> END
>>> ./mapserv -vMapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>>> OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
>>> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER
>>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT SUPPORTS=FASTCGI
>>> SUPPORTS=GEOS INPUT=TIFF
>>> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>> Here's hoping you can help.
>>> Tony
>>> Tony Baylis
>>> Ph 3832 1600
>>> Fax 3832 1603
>>> Mob 0419 759 131
>>> www resexmap.com.au
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
