[mapserver-users] Query feature using openlayers and mapserver
P Kishor
punk.kish at gmail.com
Thu Oct 29 08:44:09 EDT 2009
On Thu, Oct 29, 2009 at 1:13 AM, Aypes <apestgas at yahoo.com.hk> wrote:
> Dear all,
> I might open a topic in a wrong forum, because I do not know whether I
> should ask this question in Mapserver or OpenLayers forum. If I did, I feel
> sorry about that.
> I want to query the layer with using openlayers. However, I do not know how
> to 'call' the templates from mapfile to the html file.I have found topics
> about query using mapserver and openlayers, but I have still no idea how to
> code in html file. The query function is fine when using mapserver alone.
> In the mapfile, I have put metadata into web like this:
> WEB
> HEADER "/ms4w/Apache/htdocs/web_header.html"
> FOOTER "/ms4w/Apache/htdocs/web_footer.html"
> EMPTY "empty.html"
> Metadata
> "wms_title" "WMS"
> "wms_onlineresource"
> "http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/Apache/htdocs/test.map&"
> "wms_srs" "EPSG:4269"
> "wms_feature_info_mime_type" "text/html"
> END
> template "/ms4w/Apache/htdocs/web.html"
> imagepath "/ms4w/Apache/htdocs/tmp/"
> imageurl "/tmp/"
> END
> PROJECTION
> "init=epsg:4269"
> END
> And in the layer, data from postgresql postgis (with attribute ID) was used
> with metadata:
> Name "Abc"
> metadata
> "wms_title" "Abc"
> End
> I also have put header footer in layer and template in the class
> Class
> Name "abc"
> Template "/ms4w/Apache/htdocs/query.html"
> END
> The code in html file:
> var layer = new OpenLayers.Layer.MapServer( "ABC WMS",
> "http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/Apache/htdocs/test.map&",
> {layers: 'Abc'} );
> I tried {layers: 'Abc', mode: 'query', params ='ID'} but it did not work.
> I found an example of query: http://www.co.sweet.wy.us/mapserver/map.html
> I want to query the layer by a click instead of dragging and a new window
> come out to display information.
> How can I make this in html file?
> Furthermore, I find many examples using new OpenLayers.Layer.WMS. But when I
> use it, it displays nothing. I can only use new OpenLayers.Layer.MapServer
> to display map. What is the problem?
Here is how I did it, and it worked for me (test for typing errors)
Step 1: In the map file
Step 1a: WEB
WEB
# WMS server settings
METADATA
END
END # WEB
Step 1b: LAYER to be queried
LAYER
NAME 'layer_name'
METADATA
'wms_include_items' "FiEld_NaMe" # field name is possibly
# case-sensitive in the case of
# shape files
END # METADATA
DUMP true
HEADER "/absolute/path/to/template_header.html"
TEMPLATE "/absolute/path/to/template_body.html"
FOOTER "/absolute/path/to/template_footer.html"
END # LAYER
Step 2: In your HTML templates
Step 2a: in template_header.html
<!-- MapServer Template -->
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/transitional.dtd">
<html>
<head>
<title>MapServer Template Sample</title>
</head>
Step 2b: in template_body.html
<body>
<b>FiEld_NaMe:</b> [FiEld_NaMe]
</body>
Step 2c: in template_footer.html
</html>
Step 3: In your HTML file with OpenLayers code
map.addControl(
new OpenLayers.Control.WMSGetFeatureInfo(
function() {
return {
url: "/url/to/mapserv",
maxFeatures: 1,
title: 'Identify features by clicking',
queryVisible: true,
layers: [layer_name],
vendorParams: {
map: "/absolute/path/to/mapfile"
eventListeners: {
getfeatureinfo: function(event) {
map.addPopup(
new OpenLayers.Popup.FramedCloud(
"chicken",
map.getLonLatFromPixel(event.xy),
null,
event.text,
null,
true
true
); // map.addPopup
} // getfeatureinfo
} // eventListeners
} // return
).activate();
Puneet Kishor http://www.punkish.org
Carbon Model http://carbonmodel.org
Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
Nelson Institute, UW-Madison http://www.nelson.wisc.edu
Assertions are politics; backing up assertions with evidence is science
Sent from Madison, WI, United States
